Engine makes squeaky noise
It has been getting a bit colder and all of a sudden i hear a squeaky noise, and it doesn't seem to go away even after normal operating temperature. I have included a video, any ideas?
Thanks!
Thanks!
Chirp from Timing Belt Area TSB...you'll have to search for it.
It requires the installation of a shim kit; how many miles are on your car?
It might be covered under warranty.
takin care of Business in
Received 4,732 Likes
I think it sounds like your power steering pump:
1> check if ther are any bubbles in the PS reservoir, if they are then replace your oring...
2> check the belt....make sure the belt is tight and not slipping
Here is the DIY to replacing the oring....remember to top off the fliud after you do the oring change:
https://acurazine.com/forums/3g-tl-problems-fixes-114/diy-105-power-steering-whine-fix-754586/
rockyboy
08-04-2024 10:35 AM
Mike Bertram
09-10-2015 09:27 AM
