engine light blinking video included
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
so after installing my injen CAI I was messing around with the car and decided to make a little video of it..... when I later watched the video I noticed that the engine light blinked 3 times, is this normal?
here is the video http://s8.photobucket.com/albums/a6/...91102-0025.flv
B A N N E D
how long did you wait for the computer to relearn after the intake install, cause a blinking check engine light normally means that the computer sees that the cat is in intiment (spelling???) danger/damage and goes into protect mode
the computer should have logged it in memory, so get it checked
B A N N E D
the computer should have logged it in memory, so get it checked![2 Cents](https://acurazine.com/forums/images/smilies/2cents.gif)
geneally caused by \/ (misfiring)
B A N N E D
btw: to many members down south
![Yuck](https://acurazine.com/forums/images/smilies/yuck.gif)
I drove the car for about an hour with the intake installed before taking that video..... ill try making another video at the same speed and see if it happens again... what could cause the misfire? the car has 60 000 miles the spark plugs should be ok although I do plan on changing them soon
It probably just an emissions code.. could be a misfire, or AF ratio is too lean / rich especially with high RPM's & a new intake. Don't worry about it.. it's not catastrophic as it was suggested.
B A N N E D
HeloDown
09-08-2015 06:51 PM
