Engine getting louder around 100k miles?
Old Mar 24, 2011 | 12:51 PM
badboy's Avatar
The 3G TL is at 96K and I hear noise from the engine compartment that was not present when the car was newer with less mileage. It's faint, but still annoying.
I recently did the timing belt service which also replaced the water pump. Tomorrow, I am getting the valves adjusted and spark plugs replaced. Transmission fluid is also being replaced (3x drain/refill).
Is there any other service item I could do to lessen the amount of noise?
I understand without hearing the noise you guys don't really have much to go on. It just sounds like the engine is louder than before.
p.s I am aware I posted in the car talk forum and not the 3g tl forum.
Old Mar 24, 2011 | 12:54 PM
NSXNEXT's Avatar
Sounds like you're due for a valve job. Once it's done see if that fixes it.
Not sure if the 3rd gen has a purge control solenoid, but it tends to tick when it gets up in age. Nothing to worry about, it just gets noisy. Sounds like valve tick.
Old Mar 24, 2011 | 02:54 PM
v6cord2k5's Avatar
seizure force field!
My car sounded like it has had valve tick since the day I bought it. Lately I've noticed it has been running very smooth though. At a stop light, the car will idle perfectly and I immediately look at my RPM's expecting the car to be shut off.
The car has 70k+ miles and on it's second automatic transmission. Acceleration is a different story (car makes a rattling noise from a dig, bad axle?) and after a cold night the power steering pump whines like a mo-fo until it warms up.
Old Mar 24, 2011 | 03:40 PM
SuperTrooper169's Avatar
In the Mid-South meow
You know a $0.10 new o-ring fixes the power steering pump noise, right?
Old Mar 24, 2011 | 05:22 PM
VQPower37's Avatar
sounds like the car needs a valve adjustment soon esp at that mileage
Old Mar 24, 2011 | 06:54 PM
Moog-Type-S's Avatar
The sizzle in the Steak
Did you do the hamster replacement at 80k as stated in the owners manual?
Old Mar 24, 2011 | 07:38 PM
v6cord2k5's Avatar
did that already... Topped it off too, I suppose it tore
Old Mar 28, 2011 | 09:10 AM
juniorbean's Avatar
Based on the lack of replies here, I'm going to shuffle this over to the TL forum to see if you can get more answers there from other TL owners...
Old Mar 28, 2011 | 09:20 AM
dc5k20z1's Avatar
ditto on valve adjustment
Old Mar 28, 2011 | 10:06 AM
user 0579729724's Avatar
09 Accord Coupe 6 Speed
Belt tensioner replaced?
Old Sep 12, 2013 | 10:02 AM
VanGuy's Avatar
Please update on if the valve job fixed the note issues. Your pm's are turned off so I couldn't ask you directly unfortunately.
Old Sep 12, 2013 | 10:57 AM
350's Avatar
350
My first ricer
Check for exhaust leaks? I know I've seen people with cracked J pipes on here or the flex part is leaking a little.
vaughanml2
Nov 1, 2021 10:16 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
Desert Ridge
Sep 5, 2015 09:47 AM
