Engine braking is too loud
Old Mar 10, 2011 | 12:28 PM
dreaddark's Avatar
Help guys, anytime I use engine braking or letting go of my accelerater and when the rev goes down, it makes that engine braking, winding sounds. Its definitely louder than it should be but doesn't happen all the time. Sometimes its just a normal quiet ride. I notice its louder in 1st and 2nd gear where engine braking is more powerful and from then it progressly goes softer and softer. Clutch needs replacement?
Old Mar 10, 2011 | 12:29 PM
auto or 6MT?
your post wasnt clear, and it could go both ways.
If you are 6MT, you are not properly downshifting.
Old Mar 10, 2011 | 02:44 PM
needfd's Avatar
6th Gear
are you using the engine break technique by using 1st gear? I sure hope not. If you are using engine break you should be using 2nd 3rd gear and i hope you're watching those revs.. seriously, use the brakes as much as you can to stop the car, only use engine break if you feel like you need extra "stopping power"
Old Mar 10, 2011 | 03:01 PM
ez12a's Avatar
the overexplainer
if this is a 6MT you probably shouldnt be engine braking in 1st gear.. Might as well just use your regular brakes at that point.
When downshifting I go to maybe 2nd..3rd is usually good enough for me to make a slow turn.
If you're going down a hill that's steep enough to actually spin the engine faster the engine could potentially get louder, but that's usually if you're in the upper RPM range such as ~3k while engine braking. But my point still stands, you should not need to downshift into 1st unless you're in a parking lot.
Old Mar 10, 2011 | 05:41 PM
I hate cars's Avatar
Do you have aftermarket exhaust? Sometimes decel can be as loud as acceleration.
Old Mar 10, 2011 | 05:51 PM
dreaddark's Avatar
Sorry, 6MT.
Sorry again, i think i wrote my last sentence wrong. I dont use first gear to engine brake. I meant to say 1st and 2nd where the gears are at its highest power.
I just came back from driving again and it's makes that motor-y winding noise in 1st and 2nd gear, which sounds like engine braking noise. I thought it makes that noise only when i engine brake, but its not. Anytime i am in 1st and 2nd gear, i hear it.
Side rant: Why is it that i cant edit my original post?
Old Mar 10, 2011 | 05:57 PM
friesm2000's Avatar
B A N N E D
Originally Posted by dreaddark
Sorry, 6MT.
because the motor has the highest mechanical advantage in those gears, which is also why it accelerates the hardest in those gears
side rant: because you are a slow ass , but anyway there is like a 15 minute edit window after posting, which you may edit, after that only mods can edit it for you
Old Mar 10, 2011 | 06:30 PM
Bearcat94's Avatar
AZ Community Team
15 minute limit (as mentioned).
It's because people have been known to start a bunch of crap and/or mis-post information, then later go back and change what they posted, either back-tracking or messing up the meaning of everything that was posted afterwards.
So, you get a little time for basic corrections, but if you don't like the over-all direction a thread takes .... .
Old Mar 10, 2011 | 07:05 PM
It might be time to check the trans starting with the fluid level. You need to determine if it's a certain rpm or only 1st and 2nd gears regardless of rpm.
fifer16
1G RL (1996-2004)
Oct 16, 2015 08:54 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
Sep 15, 2015 06:44 PM
Sep 14, 2015 10:09 PM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
