Electrical problem with car? help.....
Old Nov 26, 2014 | 08:22 PM
chasingthecool's Avatar
everytime i unlock the door with my remote the passenger side mirror resets and starts moving up by itself, i would have to adjust the mirror back down....i get out of my car and go grocery shopping and when i come back to unlock the door the mirror will automatically move back up again
the memory seats dont work as well.
Old Nov 26, 2014 | 08:28 PM
MyGuti's Avatar
I've had this problem twice now. Both times, when I unlocked my car, the passenger side mirror would turn inwards until it couldn't anymore, and then it keeps on trying to turn thus making a clicking sound each time. I repositioned the mirror and pressed the "memo button" and then "1" to restore my settings. Haven't experienced the problem since, dunno why it happens :S
Old Nov 26, 2014 | 08:30 PM
my memo buttons dont work either
Old Nov 26, 2014 | 08:40 PM
MyGuti's Avatar
check your fuses
Old Nov 26, 2014 | 08:43 PM
check your fuses
i dont know how to check anything smh @ me
Old Nov 26, 2014 | 09:50 PM
rubenders's Avatar
performace tl-s
your problem is the lateral or vertical position sensor in the mirro
If those sensor goes out the memo system stop working.
Old Nov 27, 2014 | 08:55 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
With the controls, move the mirrors in all directions until you hear it clicking a few times then press your memory setting and make sure it goes where it's suppose and see if it happens again. I remember this happened to me a long time ago
Old Nov 27, 2014 | 09:05 AM
Also check fuse 20
https://acurazine.com/forums/problem...roblem-767301/ <- link to read
Old Nov 27, 2014 | 02:15 PM
truonghthe's Avatar
Make sure you move the seat and side mirror into your position then press memory the select the key fob you actually having #1 for driver 1 position 1, number 2 only for driver 2 key fob 2 sound like your fob letter is wear off so you don't know which one. If you don't want any adjustment then press lock and unlock at the same time and hold until the light lit up to disconnect the memory function.
Old Nov 27, 2014 | 08:33 PM
csmeance's Avatar
I replaced the mirror actuator for $30 on the passenger side and it fixed the memory seats in my 04
Feb 25, 2020 09:57 AM
lland
Oct 4, 2015 04:47 PM
jordanboi
Sep 5, 2015 01:33 AM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
Aug 30, 2015 02:39 PM
