E-Brake Gone????!?!?
Old Jul 20, 2008 | 08:40 AM
Black_dc2's Avatar
Stacking chips.
I changed my rotors and pads on the back of my tl yesterday. Now i have no e-brake. So I was afraid the inner shoes were out of alignment. So I pulled them back off, and rechecked clearance. Used the adjustment and tested the handle, which held the rotor to the point I couldn't turn it. So I put everything back together and still no e-brake!! Help?
Old Jul 20, 2008 | 03:22 PM
csmeance's Avatar
did you readjust the e-brake per the rotor installation instuctions? Look in the 3G garage for the service manual scans, but from what I can remember, turn the adjustment screw on the hub to full lock, then unwind 8 clicks.
Old Jul 20, 2008 | 04:50 PM
01tl4tl's Avatar
iirc- its adjust park brakes till the rotor wont turn by hand, then -6- clicks backed off- so you hear only a slight drag as the rotor turns
Old Jul 20, 2008 | 06:22 PM
Inaccurate's Avatar
Did you check that no brake fluid leaked into the drum brakes (e-brake shoes) while bleeding the rears ?
Old Jul 20, 2008 | 09:15 PM
01tl4tl's Avatar
If you can get brake fluid in the shoes while they are inside the rotor! thats pretty neat trick!
Perhaps the hand brake adjuster was turned the way up, and you need to release IT first, then adjust the brake shoes- then adjust the hand brake activation of the PARK brakes.
Anyone who has seen them KNOWS they are not for stopping in an emergency~
they are the smallest set of drum brakes known to man, they fit inside the center hub of the rear rotor---not much room there! On a good day, properly adjusted, they will reduce the strain on the transmission gears when parked on a hill.
Old Jul 20, 2008 | 10:02 PM
Inaccurate's Avatar
That bring up the classic saying "It's possible but not probably."
I am a very careful person..so I won't do that. However, I have seen some guys work on cars... and they scare me.
Old Jul 21, 2008 | 01:00 AM
Black_dc2's Avatar
Stacking chips.
I had looked, but I couldn't find anything on the rear discs as far as adjustment.
Old Jul 21, 2008 | 03:54 AM
csmeance's Avatar
check out this thread from the 3G garage, look under parking break adjustment...
https://acurazine.com/forums/showthread.php?t=118283
Old Jul 21, 2008 | 05:53 AM
01tl4tl's Avatar
oh no- another DIY to write!
I even bought a widescreen monitor so I could do the project, but it seems I do not have enough video card for the thing??? and its doesnt want to take to cd.
So its back to the store more a more low tech device,,, more suited to my computer skills.
2 things in life I just dont understand
Women and computers
Oh sure, I can push all the buttons,,,,but neither seem to do what I want!
Old Jul 21, 2008 | 08:08 AM
Black_dc2's Avatar
Stacking chips.
Thanks, I'll try that adjustment. It mentions break-in, what is the process for the rear? And do I need to go ahead and replace the shoes?
Old Jul 21, 2008 | 12:35 PM
01tl4tl's Avatar
Unless you have driven off with the park brake on several times- the shoes themself dont see a lot of wear- since they car is normally stopped and parked when they are in use~
Just adjust them correctly and try it.
NOTE the rear calipers and regular brake pads must be removed for this adjustment or you cant hear the park brakes as they drag and get tight while turning the rotor by hand
r3mix3r
Jan 9, 2008 09:14 PM
teh CL
Jan 27, 2005 11:29 AM
white99cl2.3
Dec 4, 2004 10:41 PM
ju5tchi11in
Feb 18, 2004 11:33 PM
Nashua_Night_Hawk
Feb 23, 2003 07:38 PM
