dust/pollen filter replacement
Old Sep 26, 2007 | 12:42 PM
Natedap's Avatar
I need to replace the dust/pollen filter on my 2004TL. I heard it is easy. Detailed instructions and a source for the filter would be a great help.
Old Sep 26, 2007 | 01:03 PM
timmahh's Avatar
it's me, Alan Rickman.
You need to replace the dust/pollen filter in your 2004TL. You heard it was easy. Detailed instructions and a source for the filter would be a great help.
Instructions: use the search / check 3G Garage
Source: Dealer, Internet, Kragen, Autozone, Pepboys, NAPA
Old Sep 26, 2007 | 01:36 PM
Bearcat94's Avatar
AZ Community Team
He's new. Probably hasn't found the Garage yet.
3G Garage: https://acurazine.com/forums/showthread.php?t=84831
Air Filtration 3G Garage DIY F-130: https://acurazine.com/forums/showthread.php?t=87494
DIY: Replacing Cabin Air Filter 3G Garage DIY F-130 With Pics: https://acurazine.com/forums/ramblings-12/firewall-help-123884/
Cabin Filter Replacement Mod... 3G Garage #F-130 No Glove Box Removal Mod: https://acurazine.com/forums/showthread.php?t=131831
Old Sep 27, 2007 | 06:40 AM
Natedap's Avatar
Thanks to all you guys that replied so quickly. Great photos & instructions. I'm off and running.
Old Sep 27, 2007 | 12:22 PM
harddrivin1le's Avatar
I don't understand why the process is so much more difficult than it was in my '04 and '06 Accords.
All I had to do in that was push in the glovebox stop and let the box drop to its lowest position. The filter was sitting right there.
The entire process literally took 1 minute and required no tools of any kind.
Old Sep 27, 2007 | 04:36 PM
Turbonut's Avatar
I also don't understand why Honda/Acura made it such a chore to replace the filter, but on my '04 the glove box doesn't need to be removed as it can come out with the dash, then access to the filter box is easy. Probably take maybe 5 minutes tops, but not a 1-minute job.
Many threads on the filter replacement as you could spend hours reading.
Old Sep 27, 2007 | 04:59 PM
THTL's Avatar
which filter are you guy using.
Old Sep 27, 2007 | 06:33 PM
JDM5lugHatch's Avatar
Now with i-Vtec
Yep get your Dremmel ready. I cut the slot out behine my glovebox so I could just pull and replace it within mins. Made life so much easier not only for me but for whomever has the car now.
Old Sep 27, 2007 | 07:33 PM
Turbonut's Avatar
Many aftermarket filters available with various ingredients, but I stayed with the factory filter.
Old Sep 28, 2007 | 03:30 PM
timmahh's Avatar
BOSCH Hepa TypeR
Old Sep 28, 2007 | 03:38 PM
THTL's Avatar
i though the BOSCH does not fit or i could be wrong. Where do you get it.
nanos
Nov 12, 2015 08:41 PM
ibGTV
Sep 28, 2015 03:40 AM
Skirmich
Sep 15, 2015 06:41 PM
datadr
Sep 12, 2015 09:12 PM
Aleax
Sep 9, 2015 08:04 PM
