DRL problems?
Old Feb 25, 2009 | 09:16 PM
badteddy's Avatar
DRL problems?
does anyone have any DRL problems such as... how i cant turn it on by itself...? its got its own twist switch next to my headlights, however i notice alot of people are able to turn it on without the need to have the headlights on. they will only turn on when the headlights are on... not even the parking lights will allow the DRL to come on. any help and/or suggestions is appreciated.
Old Feb 25, 2009 | 09:39 PM
Jesstzn's Avatar
You talking about the Daytime Running Lights? Or the fog lights?
As far as I know the DRLs don't have an on / off switch, they come on when you start the car. And can only be off with the car running IF the park brake was set before the car was started.
Old Feb 25, 2009 | 09:47 PM
badteddy's Avatar
daytime yes. and mine does have a switch. its labeled DRL. my tl is 2006
Old Feb 25, 2009 | 10:30 PM
Jesstzn's Avatar
So is mine a 06 but Canadian.
Old Feb 26, 2009 | 01:21 AM
badteddy's Avatar
ic. mines US.
Old Feb 26, 2009 | 08:36 AM
Jesstzn's Avatar
Turn the fog lights on and off by
turning the switch next to the
headlight switch.
You can use the fog lights only when
the headlights are on low beam.
U.S. models only
Fog Lights, Instrument Panel Brightness
Correct me if I am wrong but I don't think the DRL have a control .. the manual doesn't mention one.
https://techinfo.honda.com/rjanisis/...606O00082A.pdf
Old Feb 26, 2009 | 12:08 PM
badteddy's Avatar
i'll take a pic of it.. and i dont have fog lights.
Old Feb 26, 2009 | 12:13 PM
BG74's Avatar
All 3G TL's have fog lights except 04-06 Canadian.
Old Feb 26, 2009 | 12:35 PM
Jesstzn's Avatar
Yeep .... Our fogs were used up as DRLs because it was law up here then.
Old Feb 26, 2009 | 01:30 PM
badteddy's Avatar
not mine.
Old Feb 26, 2009 | 01:32 PM
badteddy's Avatar
Old Feb 26, 2009 | 02:20 PM
MistahSleepy's Avatar
Uh....That's the switch for the fog lights...not the DRL's
Old Feb 26, 2009 | 02:34 PM
sixsixfour's Avatar
yeah, not DRLs man. that's for the fogs. just by the way you described it tells me that its the fogs:
Old Feb 26, 2009 | 02:46 PM
badteddy's Avatar
how strange.. then why do i have a switch for fogs. that only turn on DRL's when headlights are on. and as the picture illustrates it, i do not have fog lights.
Old Feb 26, 2009 | 02:50 PM
sixsixfour's Avatar
im guessing you bought that car used, and the previous owner may have done a mod to turn those on using that alternate "fog" switch.
but definitely that switch on the stalk is the OEM foglight switch. on your particular model (2006, like mine), the foglights are "in-line" with the low beams. to the average person, when you have them lit, they think you have your highbeams on.
Old Feb 26, 2009 | 02:56 PM
badteddy's Avatar
i see. thank you. you given me the best answer. i didnt think of the previous owner modifying anything. but should i not be able to turn them on without having to turn the headlights on by themselves?
Old Feb 26, 2009 | 04:21 PM
sixsixfour's Avatar
im not sure how the wiring was probably done on that car. i have 0 knowledge on electrical wiring, so its anybody's guess how that was wired.
i believe the ones you see here on acurazine that have these fogs "on" independent of the low beams/parklights have the "foglight mod" (as its called). basically, the wiring for the fogs are intercepted/spliced somewhere under the hood and onto a separate switch. i personally would like to do it myself but i just dont have the courage nor the knowledge.
Old Feb 26, 2009 | 08:19 PM
05BlkTL's Avatar
the fogs only come on when the low beams are on, they can't be switched on without them. when you switch to high beam the fogs will cut off and the highs will come on. The newer models starting in 07? (correct me if i am wrong) have the fogs in the lower front bumper.
Old Mar 1, 2009 | 10:31 AM
badteddy's Avatar
when i switch the headlights on, the DRL stays on, even when i put highbeams on they stay on.
Old Mar 1, 2009 | 11:16 AM
import4life's Avatar
On my 04 Tl it did the same and from what i read on this site the 04-06 TL have fog lights on the actual headlights and not down on the bumper. And the fogs would only come on with the headlights on. But i did this mod (https://acurazine.com/forums/3g-tl-2004-2008-93/diy-installation-daytime-running-lights%2A%2A-detailed-pictures%2A%2A-3g-garage-g-067-a-596398/) and now i have DRLS on a separte switch. hope this helps
Old Mar 1, 2009 | 11:24 AM
OR if you want to save some money you can also do this mod that has also worked great on other members cars https://acurazine.com/forums/showthr...highlight=drls
Old Mar 2, 2009 | 09:31 PM
badteddy's Avatar
thanks import4life. thats exactly what i needed
SidhuSaaB
May 30, 2020 12:40 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
