Drivers Window Auto Feature FAIL
Old Feb 19, 2009 | 01:07 PM
BLACKURA_NY's Avatar
I have car ADD
So, last night.. for the THIRD time since i've bought my type-s... My battery died (almost.. i had to crank the car 4 times until it kicked over)
Since then... my Drivers side window.... the Auto Up/Down feature doesnt work!! The window still works, but the auto down/up doesnt.. if i press it slightly or hard.. doesnt matter
any thoughts/suggestions? I'm confused... dont feel like bringing my car to the dealership over this...
Old Feb 19, 2009 | 01:38 PM
6MTProwler's Avatar
Death Before Dismount
Yea you gotta reset your car. Unhook the battery for 10 mins and then start again.
This happens to me too when my car likes to randomly loose all power when I shut it off.
Old Feb 19, 2009 | 02:01 PM
RACINGHART03's Avatar
Relearn it. Once you run the window to the top hold it for five secs. Window control unit loses memory when the battery dies.
Old Feb 19, 2009 | 02:29 PM
PeterUbers's Avatar
run the window all the way down, keep holding 10 seconds after totally down... then immediately run window up and hold 10 seconds past it being totally closed... problem solved.
Old Feb 19, 2009 | 02:32 PM
Majofo's Avatar
Good to know!
Old Feb 19, 2009 | 02:39 PM
I have car ADD
thanks guys. ill try in a few minutes
Old Feb 19, 2009 | 03:38 PM
PeterUbers's Avatar
battery dying for the third time... hmm.... what's drawing current and draining your battery?
I see a Viper r/s in your sig.... wonder if it's overdrawing current (alarm, anti-grind/starter disable relay) .. i'm assuming your battery is otherwise fine and it's being charged appropriately...
Old Feb 19, 2009 | 03:41 PM
Majofo's Avatar
My Viper system would drain my Optima Yellowtop if I left it for extended periods (over 2-3 weeks) on my '93 Accord.
edit: I'm kinda suprised you got it to crank. When my OE battery died, before I replaced it, It just went *click *click.. nothing.
Old Feb 19, 2009 | 04:35 PM
I have car ADD
i think its just the crap OEM battery.... i wont lie, i was sitting in the car for about....45 minutes on the phone, but i was in (I) position, so only the radio was on... ive had cars that i can sit for 2 or 3 hours with no problem....
i really need to replace them OEM battery.... the first 2 times it died... i had NO reasoning as to why.... the car sat still for about 16 hours... but it was dead as a door nail
Old Feb 19, 2009 | 04:36 PM
I have car ADD
the first 2 times, i had to jump... this time, i was about to go inside, realized i had been in the car for about 45 minutes, and decided to let it run before i went to bed for the night... first 2-3 times i flicked the key, it sputtered, and stopped (1 touch starting in 07+) the 4th i held the key down, gave it gas ( i know, its FI, it shouldnt make a difference) but the car fired right up !!!
I have car ADD
worked like a charm
thanks man!!!!!
Old Feb 19, 2009 | 07:25 PM
Originally Posted by BLACKURA_NY
worked like a charm
thanks man!!!!!
Word. See ya on the 22nd.
Old Feb 19, 2009 | 10:18 PM
PeterUbers's Avatar
this should be a sticky .. it's been asked quite a few times now..
Old Feb 20, 2009 | 12:19 AM
TLAdvanced's Avatar
The Kinetics of Bleu
I agree it deserves a spot in the 3G garage...
Old Feb 20, 2009 | 03:05 AM
Elegant TYPE S's Avatar
Being an Acha Bacha in
Yeah had the same shit happen to me once. Also.. bro.. if you replace your battery look to see if you can upgrade to a Braille or some shit and then get a refund from ACURA for the difference. Worth while doing.. you can get a Braile or Optima for like a little over 100 bux if you do it that way.
Old Feb 20, 2009 | 04:29 AM
con5tant's Avatar
this happened to my rsx also... i will try this thanks!
Old Feb 20, 2009 | 07:23 AM
This is a standard procedure on all Acura models with the auto feature.
Old Feb 20, 2009 | 02:45 PM
PeterUbers's Avatar
the procedure also works on hondas, nissans, and infinitis....
Old Feb 20, 2009 | 02:59 PM
YeuEmMaiMai's Avatar
according to the acura service bulliten it is a 2 second wait at each end, not 10......
Old Feb 20, 2009 | 03:17 PM
Who said 10?
Old Feb 20, 2009 | 05:07 PM
I have car ADD
i did it for 5 seconds... worked the first time, like a charm
Old Feb 21, 2009 | 01:08 AM
samdrvsatl's Avatar
the windows go up with the remote? mine only go down when i hold the unlock
Old Feb 21, 2009 | 07:50 AM
No he was having an issue with the auto feature and the interior switches.
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
ahsm
Sep 9, 2015 08:35 AM
gqdabien
Sep 8, 2015 11:41 PM
asahrts
Sep 4, 2015 05:55 PM
