Drivers Window Auto Feature FAIL
So, last night.. for the THIRD time since i've bought my type-s... My battery died (almost.. i had to crank the car 4 times until it kicked over)
Since then... my Drivers side window.... the Auto Up/Down feature doesnt work!! The window still works, but the auto down/up doesnt.. if i press it slightly or hard.. doesnt matter
any thoughts/suggestions? I'm confused... dont feel like bringing my car to the dealership over this...
Death Before Dismount
Yea you gotta reset your car. Unhook the battery for 10 mins and then start again.
This happens to me too when my car likes to randomly loose all power when I shut it off.
battery dying for the third time... hmm.... what's drawing current and draining your battery?
I see a Viper r/s in your sig.... wonder if it's overdrawing current (alarm, anti-grind/starter disable relay) .. i'm assuming your battery is otherwise fine and it's being charged appropriately...
My Viper system would drain my Optima Yellowtop if I left it for extended periods (over 2-3 weeks) on my '93 Accord.
edit: I'm kinda suprised you got it to crank. When my OE battery died, before I replaced it, It just went *click *click.. nothing.
i really need to replace them OEM battery.... the first 2 times it died... i had NO reasoning as to why.... the car sat still for about 16 hours... but it was dead as a door nail
the first 2 times, i had to jump... this time, i was about to go inside, realized i had been in the car for about 45 minutes, and decided to let it run before i went to bed for the night... first 2-3 times i flicked the key, it sputtered, and stopped (1 touch starting in 07+) the 4th i held the key down, gave it gas ( i know, its FI, it shouldnt make a difference) but the car fired right up !!!
Being an Acha Bacha in
Yeah had the same shit happen to me once. Also.. bro.. if you replace your battery look to see if you can upgrade to a Braille or some shit and then get a refund from ACURA for the difference. Worth while doing.. you can get a Braile or Optima for like a little over 100 bux if you do it that way.
according to the acura service bulliten it is a 2 second wait at each end, not 10......
TLDude876
12-28-2016 03:18 PM
ahsm
09-09-2015 08:35 AM
asahrts
09-04-2015 05:55 PM
