Drivers side window question
Old Jun 18, 2006 | 05:20 PM
TL A-Spec Owner's Avatar
GO BLUE!
I have a problem with my drivers side window. If this has been asked and answered already, I appologize in advance.
The problem is this: when my window is rolled down all the way and I try to have the window automatically roll up, the window stops itself about 2/3 of the way up and than proceeds to roll itself back down to the open position. It may do this again, it may not. I can then usually manually roll it back up or try the auto roll up with no problem. I thought it might be an isolated incident, but it has happened more frequently lately. It does not, however, happen every time I try to roll the window back up. Any thoughts or ideas about what the problem(s) might be?
Old Jun 18, 2006 | 06:21 PM
KJSmitty's Avatar
WDP Director of R & D
I'm no expert on the mechanics/electronics of the TL window circuit but.... It sounds like their may be too much tension/drag in the window regulator and the anti-jam sensor/feature (someone/kid getting arm/head stuck in window etc.) reverses the window. If so it would do this if you used auto up or manually held the "up" switch the entire time.
Most likely will require a trip to the dealer for warranty..
Old Jun 18, 2006 | 06:42 PM
subinf's Avatar
One on the right for me
been asked a few times in Problems and Fixes. Its most likely the window regulator...dealer replaced mine under warranty.
Old Jun 19, 2006 | 12:02 PM
khiyal's Avatar
https://acurazine.com/forums/showthread.php?t=133215
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
gqdabien
Sep 8, 2015 11:41 PM
