Driver's seat/Memory Seat issue
Old Jul 14, 2020 | 06:17 PM
robstercraw's Avatar
2008 TL-My Driver's seat memory function stopped working completely. I also notice that when I manually use the switch to move the seat back and forth, the seat does move about 2 inches and stops. If I click it again in the same direction it moves another 2 inches. So, the motor works fine, the switch to move the seat back and forth works fine, its just not continuous.
I do also have the passenger grinding mirror problem as well.
Any idea on the seat issue?
Old Jul 14, 2020 | 09:26 PM
vpasla1's Avatar
Mirror actuators. Change them.
Old Jul 15, 2020 | 03:09 PM
BillMFD3's Avatar
There is a drive cable under the seat. Mine popped out from the gear assembly and had to be bolted back in. Made a rattling noise before is happened, I thought I had dropped some change above the seat rail 😂
AlanW
1/2G MDX (2001-2013)
Mar 25, 2018 05:31 PM
Stiffy
2G CL Problems & Fixes
Feb 22, 2016 04:02 PM
TypeRod
1G CL Problems & Fixes
Nov 10, 2010 01:47 PM
Raheel
Aug 24, 2003 11:30 PM
