Driver's door lock problem
Old Mar 23, 2020 | 06:11 PM
firebolt's Avatar
I have this problem from the moment I bought my car. When I push the button on the remote, all doors lock except the front left door. And the same way when I open doors. And there is the same problem when I use driver side toggle switch. I have to use a key every time to open/close driver's door.
I found this topic and now I know that there are 3 possible ways to fix it: replace fuse #8, replace actuator and replace MICU (or relay inside the MICU).
The fuse #8 is OK, and when I winkled it out the toggle switch on the passenger side stopped working. So, now how to figure out what exactly I need to replace: actuator or MICU? Will actuator from another door fit to the driver's door? - Just in case if I will try to check the actuators.
Old Mar 24, 2020 | 01:58 PM
GhostTL09's Avatar
have you set the computer to unlock all doors upon lock/unlock? I don't think actuators is the issue
Old Mar 24, 2020 | 02:08 PM
firebolt's Avatar
Thanks for your reply! But I didn't get your idea.
I had to set the computer to not lock the doors after XX mph, because driver's door never locks and it tries to lock the doors each time after I stop and begin moving again.
Old Mar 24, 2020 | 02:22 PM
if only the driver's door is not unlock or locking, then it sounds like the actuator is problematic.
Old Mar 24, 2020 | 02:56 PM
firebolt's Avatar
Yesterday I removed the lock from the door and connected it to the lock connectors from disassembled passenger's side. It didn't work too. So I think the problem is in the actuator.
Old Mar 26, 2020 | 07:14 PM
HVAC34's Avatar
Yeah lock actuators go bad on these cars. Mine particularly driver side because it’s just me in the car. I’m going on my second replacement in 3 years with oem Honda. 😞
Old Mar 27, 2020 | 02:12 AM
firebolt's Avatar
Maybe this time you should try third party?
Old Mar 27, 2020 | 04:28 PM
DMZ's Avatar
DMZ
Head a da Family
As always, try rockauto! Got my actuators from them and they work just fine!
VietNinjaJ30A1
1G RDX Problems & Fixes
Jan 23, 2025 03:31 PM
04tldude
Jan 4, 2020 12:03 AM
Pull_Up_Selecta
Dec 1, 2014 02:40 PM
nollid
Dec 24, 2012 03:50 PM
bgl2687
May 9, 2007 01:07 PM
