Help:Key fob wont unlock passenger door.
The passenger door wont unlock from the key fob or the switch from inside the car. The only way the door will unlock is if I manually pull it up. It also wont lock so I have to manually push it down to lock the passenger side door. All the other doors work. What can be the problem?
sounds like it came apart on the inside. You will most likely have to pull out off the door panel and give it a visual and look for the parts that aren't connected to anything else. Start by looking for the motor that locks and unlocks it and follow the line from there.
I have the same problem but its with all the doors minus the driver side. But for me the problem comes and goes. Like ill go to store and all the doors WONT unlock, when I'm leaving the store then the doors WILL unlock. Very weird to me. And usually when my power doors don't work the windows won't either. Any ideas?
soupi
14
Nov 15, 2015 11:15 AM
