Rotor ques
Old May 7, 2007 | 03:46 PM
Got_3.2?'s Avatar
Rotor ques
hey i looked at my rotor today and my passenger side rotor is starting to get grinded down. what can be causing that to happen? my rotors are slotted powerslots with shitty pads. its starting to get worst now. can it be the caliper or maybe something is loose? im planning on buying new rotors and pads this week but dont want my new rotors to get grinded down like whats happening now.
thanks
mike
Old May 7, 2007 | 04:07 PM
fsttyms1's Avatar
What do you mean by grinded down? Is it all rough? just showing more signs of wear than the others? I would take the caliper off and see if the pads are in good shape or are completely worn out.
I would also look for wearing or some type of caliper to rotor touching to see if any part is touching. thats not supposed to be
Old May 7, 2007 | 10:54 PM
Got_3.2?'s Avatar
yea like theres deep grooves on the pass side rotor. now when i brake my pedal basically touches the floor all the way unless i pump the brakes. my tcs and abs light are on constantly now. the pads were put on about 2 months ago.
Old May 7, 2007 | 11:04 PM
01tl4tl's Avatar
Powerslot rotors- and all rotors with extra holes and cuts on the side, wear out pads.
I am ~GUESSING~ since you ar running "shitty pads" that those were a replacement set?
Cheap pads will not last on heavy duty rotors
How many sets of pads on these rotors?
If there is deep grooving in the rotor it means the pads have worn down to the metal backing plate and your braking system is now working in a very different way.
The caliper piston may soon pop out, or get stuck or the rotor could be cut thru at its base
STOP DRIVING and remove the wheel and inspect the brakes NOW
Your insurance company would dishonor any claim of you running into someone with BAAAAAD brakes!!
Old May 8, 2007 | 09:12 AM
fsttyms1's Avatar
. First sign that something is wrong is when you have grooves in the rotor. 2nd sign is when you have warning lights on the dash. Id take the wheel off and inspect the pad to make sure there is pad material left. Also check that your brake fluid level is normal.
Old May 8, 2007 | 03:47 PM
Got_3.2?'s Avatar
im ordering new rotors and pads today thru excelerate. gonna have them installed on sat since thats the only day i can really get it done. i go to the police academy 8-4 then work 5-11. i dont drive it far. total 10 miles per day since both are right by my house.
Old May 8, 2007 | 09:19 PM
01tl4tl's Avatar
Did someone- a professional mechanic- check the calipers for you to make sure its just a problem of worn out pads/parts, not bad caliper? There seems to be a few of us this week with caliper issues
Take a cab, rent a car, do anything but drive a TL with metal to metal brakes and warning lights
If you pulled over someone with that same condition - what would you say to them??
Danger on the road!!!!
Old May 9, 2007 | 11:27 AM
arshu78's Avatar
cheap pad with improper installed shim could do that. Hawk pads are preety cheap from Tirerack.com. get the rotor re surfaced.
Old May 9, 2007 | 03:37 PM
Got_3.2?'s Avatar
i just ordered my new rotora slotted with ebc green stuff pads. how its this setup? i wanted to go with powerslot and hawks but wanted to try something different.
i looked at my caliper last night and its right against my rotor. i donno how dat could happen within 5 days since i looked at it then and it looked fine. another friend of mine who owns a meineke is gonna do my brake work dis sat if i get my new rotors n pads..
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
