Driver side window won't go up
Old May 22, 2013 | 05:34 PM
Bankz's Avatar
My driver side window won't go back up but I can hear the motor running when I press the power window button to try and make it go up. Some feed back from fellow azine members will much be appreciated thanks
Old May 22, 2013 | 06:03 PM
My"S"exyUA7's Avatar
Did you try using the remote?
Old May 22, 2013 | 06:05 PM
guitarplayer16's Avatar
My only advice is to remove the door panel and see whats going on in there.
Old May 22, 2013 | 06:08 PM
Actually... do you have tinted windows? I'll explain if you do.
Old May 22, 2013 | 08:35 PM
Bankz's Avatar
Yup windows are tinted but I bought the car like that, when I tried to pull up the window manually it looks like the regulator dropped. So I don't know if it's broken or it wasn't bolted on properly but I could go deep in my investigation as it was raining outside
Old May 22, 2013 | 08:56 PM
One day I was at hortons drive thru and as I was leaving, my window wouldn't go up either. Like you, the motor was working but the window wouldn't go up. I raced to the tint shop (-20 outside!) to pull the door panel apart and see what was going on and realized that some of the glue from the felt smeared on the window and was preventing the window from going up. Cleaned up the window and put the felt back in and it's been perfect ever since. Is your TL still under warranty?
Old May 22, 2013 | 09:09 PM
I forgot you mentioned you could hear the motor running (therefore it's not the switch) before I asked this...it's just a lot of TLers don't know that if they hold the lock button down for 3-5 seconds, it will close all the windows and moon roof (if there was something wrong with the switch) and if you hold the unlock, it will open everything.
Old May 22, 2013 | 09:19 PM
Bankz's Avatar
It's funny how mention the glue part. I did see something like glue or some grease on the window
Old May 22, 2013 | 09:22 PM
Bankz's Avatar
The switch is fine but when I pulled up the window manually I think the regulator fell so do you think it's broken
Old May 22, 2013 | 09:27 PM
Bankz's Avatar
I watched a YouTube video on how to take the panel doors off and pull out the window and the person used what appeared to be a 8 or 10mm socket to remove the regulator. So when I tried to remove the door panel I notice that I didn't have any bolts to unscrew
Old May 22, 2013 | 09:32 PM
Bankz's Avatar
So my guess is that the regulator is broken
Old May 22, 2013 | 09:37 PM
???...I'm trying to remember how they took it off (in January) but I know it was a pain in the ass.
Old May 22, 2013 | 09:40 PM
Sounds like it...sorry dude. That's what I was afraid of with my episode.
Old May 22, 2013 | 09:45 PM
Bankz's Avatar
Thanks for you help
Old May 23, 2013 | 08:38 AM
imj0257's Avatar
Q('.')=O
Does it go back up at ALL? Maybe a few inches then back down? Or doesn't go up at all?
Old May 23, 2013 | 02:51 PM
^ Something broke inside his door panel and now it don't matter...Bankz has to take it apart now...pretty sure.
Old May 23, 2013 | 02:59 PM
Thanks for you help
Anytime!...that's what we're here for.
Old May 24, 2013 | 12:51 AM
spicynoodle116's Avatar
Newb
My regulator broke also 2 months ago. I was driving and it sounded like something dropped inside the door panel. Tried to close the window, but it doesnt move and all I hear was the motor moving.
Got the regulator from ebay for $100 or so, then paid mechanic $50 to replace it. It looked pretty easy, if you wanna DIY this try to have someone hold the window in place while the other disconnect the regulator from the window to prevent it from dropping. Good luck!
Old May 24, 2013 | 12:57 AM
Bankz's Avatar
Just got everything fix I bought the part from a used part place the whole assembly for $80 and a fellow azine member and I put everything together now my window goes up and down.
Old May 24, 2013 | 01:45 AM
Smile
Hopefully that rain didn't get you too wet. It was raining pretty good when leaving clarkson. Glad to see every thing worked out for you.
Old May 25, 2013 | 01:32 AM
t0fu's Avatar
4th Gear
Anybody find a DIY on how to fix the window regulator? Unfortunately I have the same problem. Any help would be appreciated!
Old May 25, 2013 | 07:39 PM
Bankz's Avatar
I used YouTube to research on how to replace the regulator
Old May 25, 2013 | 08:02 PM
Bankz's Avatar
Man that day was crazy it was cold and windy plus I was getting wet but every thing worked out
Old May 27, 2013 | 10:57 PM
t0fu's Avatar
4th Gear
Thanks!
rockyboy
Aug 4, 2024 10:35 AM
sockr1
Oct 1, 2015 01:31 AM
govtcheez
Oct 1, 2015 12:21 AM
hand123
Sep 10, 2015 09:27 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
