Downshifted in 2nd gear, and stayed there
Old Oct 15, 2011 | 12:16 PM
Ricky Pounds's Avatar
B A N N E D
My car has been working in excellent condition, until yesterday. I was driving and suddenly it started downshifting pretty aggressively, until it held in 2nd gear! I drove it at 30mph up to the shop. The scanner showed codes 0747 and 0752, which are for two pressure solenoids. I put both of them in, it started working fine, but after 10 t0 15 minutes it started doing the same thing, and the same codes, 0747 and 0752 showed up again! Just before the problem, I installed the P2R spacer and washed the engine. I have washed the engine many time without any problem. I am just putting down everything I did before this problem showed up. We also changed the oil, and it looked perfect. The transmission was repaired completely at 94k and it has now 110k. It is obviously an electrical problem, as said by the shop. Has anyone had this problem, and if so, how has it been solved?? Appreciate any help regarding this problem!!
Old Oct 15, 2011 | 12:42 PM
rockstar143's Avatar
Shit, I wish I knew, man...I'm sure 04tl, turbonut, or IHC will chime in quickly and let you know what's up. Sorry to hear that!
Old Oct 15, 2011 | 12:48 PM
B A N N E D
Yeah man, it stinks! I pm'ed IHC as I know he may have the right feedback regarding this problem. Thanks rockstar!!
Old Oct 15, 2011 | 12:49 PM
No problem, man...trust me, I'm not stranger to the post on AZ and wait for help and response...it makes me itch with anticipation!
I wish you luck, bud.
Old Oct 15, 2011 | 11:43 PM
9632tl's Avatar
Radical Member
Maybe a shitty ground connection for both sensors? Ive had it happen with other sensors before.
Old Oct 16, 2011 | 03:14 AM
dwb993's Avatar
Check all of the connectors for the tranny---especially the one on the top near the ATF fill hole. Picture in this thread, post #31:
tl.acurazine.com/forums/showthread.php?t=754752
Old Oct 16, 2011 | 03:27 AM
STEVEN05's Avatar
my 04 TL did the same thing at 105k .At first i thought it was solinoid on top of trany but it wasn't.APP SENSOR( ACCELERATION PEDAL POSITIONING ) on ur firewall right below the brake fluid reservor.the shop changed the sensor and then it work fine now.
Old Oct 16, 2011 | 03:32 AM
STEVEN05's Avatar
the OEM sensor cost $168 and the shop charge me for diagnosed issue and installed and clear codes for about $300
Old Oct 16, 2011 | 08:39 AM
That's great info...Ricky, keep us updated on the fix please.
Also, this sensor, does it go bad on 6MT?
Old Oct 16, 2011 | 10:31 AM
swoosh's Avatar
takin care of Business in
^^^ look at you all worried J....
Ricky, did you PM IHC/Inaccurate about the thread ?
I would look into the APP sensor....Now that Steven05 mentioned this, I remember someone else posting about the same issue....sorry didnt remember this when you PM-ed me, would have solved it via PM for ya....
-1 Brownie point for me
Old Oct 16, 2011 | 10:45 AM
I'm not worried, but to be honest, most of the issues other say they have with their TL, show up somewhere down the line!
Old Oct 16, 2011 | 11:16 AM
B A N N E D
Guy's, thanks to all for your very important recommendations! Swoosh, I sent a PM to IHC and Innacurate, deffinitely waiting on their feedback! But all of the recommendation I have seen here also have weight on some of the other thing I have to consider and do! STEVEN05, I will take the APP sensor recommendation to the shop. DWB993, he did clean the two connectors of the solenoids that where changed, but deffinitely should check them all out, It may be as simple as that!! Again thanks to all of you for your help!!
Old Oct 16, 2011 | 11:49 AM
Ricky...must change avi back to previous one. That might be why the car is giving you problems...
Old Oct 16, 2011 | 12:08 PM
swoosh's Avatar
Also Ricky...did you reset the ECU....I know its sounds lame, but sometimes the stuff just needs a little reset....
Old Oct 16, 2011 | 12:34 PM
B A N N E D
Deffinitely will follow up. I just got that important PM I was waiting from IHC. He also recommends following the wirering from the two soleniods replaced, up to the harness as he say's there may be a pinched wire or something that may be affecting as a broken connection, among other things. He also recommends what you did swoosh, reseting the ECU, and will check the avi as rockstar also recommends! Damm, I am glad I posted the problem and that I have gotten so much positive responce back!! I am comfortable this problem should be solved by tommorow! Will keep everyone posted! Thanks again!!
Old Oct 16, 2011 | 12:37 PM
swoosh's Avatar
^^^ dude am glad the fog is thinning out....I hope you will be up and ready to drive in no time....
Keep the thread updated so others can use this for reference....
Old Oct 16, 2011 | 12:40 PM
B A N N E D
Count on that!!
Old Oct 16, 2011 | 03:04 PM
indeed sir...
Old Oct 17, 2011 | 02:28 PM
B A N N E D
Done every recommendation, even called the Acura dealer and they recommended the 3x3 oil change. If this does not work, it will be opened tomorrow!!
Old Oct 17, 2011 | 02:30 PM
Oh NOOOO...
3x3 shouldn't solve this problem...at least it doesn't seem like it would, no? it has to be electrical!
Old Oct 17, 2011 | 02:37 PM
B A N N E D
Oh NOOOO...
Damm rockstar, I am frustrated. Believe me when I say the last thing I want is for them to open the damm tranny. But pretty much all the recommendations IHC and Innacurate have given have been done! I was thinking in taking it to an electromechanic, what do you think??
Old Oct 17, 2011 | 07:07 PM
swoosh's Avatar
^^^ that would be the way to go...it could be as easy as a plug popped off....
if you are covered under warranty then do as the dealer says....
Old Oct 18, 2011 | 10:54 AM
^^^total concurrence.
Old Oct 18, 2011 | 01:02 PM
B A N N E D
Did'nt shift into reverse either...undergoing surgery! Warrantee will cover, will advise what they find!!
Old Oct 18, 2011 | 01:12 PM
swoosh's Avatar
^^^ @ warranty covering it
Cant wait to see/hear what they find....
Old Oct 18, 2011 | 01:18 PM
that's great news buddy!
Old Oct 18, 2011 | 01:36 PM
B A N N E D
Believe me guy's, I wanna know what happened in there!! Will post as soon as I hear some news!!
Old Oct 19, 2011 | 02:43 PM
B A N N E D
Ok guy's, here we go...5 clutches of the 3rd gear drum where shot. The parts of the clutch which came off, clogged the filters which eventually interrupted the oil pressure flow and created the jerking and gear change. With the oil pressure flow interrupted, the transmission eventually held into second gear and did'nt link into reverse either, as the clutches left a good amount of contamination. The rest of the transmission was in perfect condition. In addition to replacing the full 3rd gear clutches, my mechanic replaced the converter, inner and outer filter. Why the clutches failed...beats me!! In addition both pressure soleniods where replaced brand new, so I expect it to behave!! Thanks again to rockstar143, swoosh, STEVEN05, dwb993 and 9632tl for all you great recommendations and feedback!!
Old Oct 19, 2011 | 03:12 PM
swoosh's Avatar
Wish there was more info on "what caused it"....
But am glad you found out what was wrong and got it fixed....was this at your mechanic or Acura dealership ?
When do you get your car back ?
Old Oct 19, 2011 | 04:30 PM
and was covered under warranty??!
ZOMG...and I thought having to replace the clutch is bad in a 6MT!
Glad it's getting resolved!
Old Oct 19, 2011 | 05:32 PM
B A N N E D
You know, I have learned, not only with Acura, but prior with BMW, that after the warrantee is gone, the least place I want to take it to is to the dealer, of course only if it is totally necessary! I have a mechanic who is an ex ACURA Technitian. He opened his own shop, and ever since my car broke the warrantee, he has been servicing my car, and very well done if I may add. Obviously we have a well established relation between customer and shop as I have been his customer very close of him opening the shop. More than anything it gave weight to him honoring the warrantee for the last job done to the tranny, which expired in March of this year. I have to consider myself fortunate!! I was at the shop a while ago dropping of the oil, and they where starting to put it back together and he said it should be ready by tomorrow. Still he said he will keep it until Friday as he want's to do some field test's before he returns it. He explained he does not know what happend with the clutches in this particular drum, as they where all installed new, and the rest of the tranny is in perfect condition. Maybe he believes these particular parts where deffective, and that's why he covered it. At the end of the day I am happy that the problem was identified and fixed!! Thanks again guys!!
Old Oct 19, 2011 | 06:18 PM
ez12a's Avatar
the overexplainer
I fried my parent's 2001 Odyssey transmission going up the 5 fwy past Six Flags this weekend. 2800 for a rebuild and a 2 year warranty. That's far more in cost than any manual clutch related fix.
Mike Pilipenko
Mar 26, 2024 09:21 PM
SidhuSaaB
May 30, 2020 12:40 AM
RSpyder
Sep 30, 2015 12:46 AM
hashbrown
Sep 29, 2015 12:13 PM
