Door lock malfunction..
Old Jul 12, 2013 | 02:15 AM
thefatcat's Avatar
...sorry to flood the forum with issues
I have one other issue, when I get out of my car (while it's running) and close the door, the lock engages. I've tried messing with the settings and that does nothing.
A guy in our Acura group here in MN is an Acura mechanic and even he is stumped. Anyone else ever experienced this before? Is it the actuator in the door?
Thanks in advance.
Old Jul 12, 2013 | 10:37 AM
Vlad_Type_S's Avatar
Registered Bike Offender
All of the locks, or just the driver's door?
Maybe there are damaged contacts on the switch and when you close the door, they short circuit. It's important to know if it's the contacts on the actuator or on the lock/unlock button though.
However, I think our cars are programmed to not lock if the key is in the ignition. (Not sure how it works in AT vs MT). So if all the doors are being locked, then this system has failed. If it's just the drivers door, it's probably an intermittent short related to the actuator motor.
Pull that door panel off and see what's back there, it might be painfully obvious if something is damaged or loose. Good luck!
Old Jul 13, 2013 | 12:08 AM
thefatcat's Avatar
All doors. If I park with engine running an shut door, all locks go. If I am driving down road and hit door unlock, they stay unlocked.
It's weird
Old Jul 13, 2013 | 07:47 PM
AT or MT?
This time, instead of getting out and closing the door. Open the door and actuate the door open sensor (the black nipple that the door presses when it closes). See if it locks then.....
Old Jul 13, 2013 | 09:51 PM
thefatcat's Avatar
AT or MT?
3.2 AT
I will give that a try...
Old Jul 14, 2013 | 04:48 PM
thefatcat's Avatar
AT or MT?
Did what you said and the door sensor also makes the locks go down.
Old Jul 14, 2013 | 11:29 PM
xNPKx's Avatar
7th Gear
i had the same problem a few months ago it kept on locking for about a month or 2 i had to get a tow truck to open it for me twice =/ i was reading online some wires could have got messed up behind the side mirror button try switching it to the middle i switched it back and forth a few times and everything started working good agian LOL i don't know if it was luck or if something was just messed up but its worth giving it a try and just leaving it in the middle for a few days see how it goes
Old Jul 15, 2013 | 06:28 AM
Project_CLean's Avatar
MMkay.
I think you should read up some on the MICU of these cars, it's like the brain for all of our power accessories.
Old Jul 15, 2013 | 11:21 AM
The best kinds of problems to solve are the kind that are easily reproducible! Try the mirror switch thingy lol. Otherwise, I would probably start probing electrical signals to determine which one is not doing its job. I think that if a control module was defective, the problem would be intermittent and would likely be accompanied by other, weird, problems.
Old Jul 15, 2013 | 01:38 PM
thefatcat's Avatar
To add insult to injury, now the keychain clicker won't make the door locks close when I walk away from the car. It will unlock them (after I manually walk around the car to lock them) and it will pop the trunk.....it just won't lock them.
Old Jul 15, 2013 | 04:55 PM
I jinxed it...
Old Jul 31, 2013 | 10:31 PM
Hambone13th's Avatar
5th Gear
I have a 2005 Acura TL, I replaced the front passenger door actuator few like 3 months by disconnecting the battery to reset the "brain" to allow me to open the door.
Then just last night the same door went out, believed to to be same issue. So I attempted to reset the "brain" again and no luck this time wtf! After reading many many words of advice from other related topics I'm stuck!! I pealed back the top portion of the panel from inside the car to find out my door latch cable is broken. Using needle nose pliers I pulled on the cable to open the door.... No luck! Do I need to continue to rip off the door panel? .. Or should there be a way to open the door? I'm at wits end with Acura's, piss poor parts. Not to mention I still need to replace my clutch to my compressor for AC
MrHeeltoe
20
Feb 23, 2023 01:54 PM
soupi
14
Nov 15, 2015 11:15 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
