Air Conditioning
Old Jul 31, 2013 | 01:47 PM
skippyTL's Avatar
Air Conditioning
After working flawlessly since I've had the car, the A/C suddenly barely blows cool air. Any suggestions?
Old Jul 31, 2013 | 01:50 PM
and it feels like 105Degrees in Houston today.
Old Jul 31, 2013 | 02:23 PM
skippyTL's Avatar
Yeah - THAT too.
I can hear the A/C clutch engaging - it's just not putting out cold air...
Old Jul 31, 2013 | 02:26 PM
I'm not well versed in A/C systems.
Old Jul 31, 2013 | 02:50 PM
pohljm's Avatar
more often than not its a leak leaving you with a low refrigerant charge, but only an AC system check will be able to determine that.
Old Jul 31, 2013 | 03:28 PM
skippyTL's Avatar
Seems to have happened quite suddenly - perhaps I've been losing charge for a while and only just really noticed it....
Old Jul 31, 2013 | 04:16 PM
YeuEmMaiMai's Avatar
follow any large vehicles ?
r134a systems are very sensitive to charge levels and do not have nearly the reserve that the old r12 had..
First thing,
add some florscent dye to system
run ac
(if you have it) use a UV light to look for leaks, otherwise a high intenesity light
if found note location(s) of leak(s) and get it (them) fixed.
Most common places are
condensor
compressor seals
shroeder valves
skippyTL's Avatar
Turns out the refrigerant level was less than half of what it should have been - so I just juiced it with a recharge kit. Blows cold now.
Time will tell just how big of a leak actually exists - I'm just glad it's not the compressor!!!
Old Jul 31, 2013 | 09:11 PM
MarcoNorthPolo's Avatar
KCCO
I was going to suggest a recharge. Hopefully that will be a long term fix.
Old Jul 31, 2013 | 09:34 PM
skippyTL's Avatar
Yeah - me too. But to be honest, I've had the car for over 4 years & have never had to recharge it so I guess if it lasts, I got off light.
Old Jul 31, 2013 | 11:00 PM
pohljm's Avatar
there is a leak. it does not just loose the charge over time. you need to find the leak and fix it.
Biggie_B
May 27, 2025 05:51 PM
SidhuSaaB
May 30, 2020 12:40 AM
rcs86
Aug 2, 2016 06:52 PM
lanechanger
Oct 13, 2015 10:56 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
