DO you guys know what is this noise?
yup its your throw out bearing is going bad, be prepare to replace the clutch and fly wheel while you are at it unless you can DIY.
The DVD-A Script Guy
Nope.
I made sure to listen to you vid before looking at the other responses and also immediately thought the exact same thing as all the others. It's probably not super urgent and my guess is you can run it for quite a while, maybe even quite a while. But they don't typically "heal" so start preparing yourself for the job.
Out of curiosity, how many miles?
it happened on my 92 Legend and the day after that boom, I have to tow my car to the nearest shop. Yes you can get away with it for awhile or may be just down the road, it just luck like the roll of the dice. I would saving for a new clutch job, FYI Acura dealer want almost $2100 for the job or you can get it done for around $700-$800 by family mechanic with you buying parts.
my 98 prelude is doing that noise now and if you put your finger on the fork on the tranny it stops, now my 04 TL 6speed, that one just went out on me a few hours ago, on the days before what i would hear would be like a slight crackling noise coming from the tranny at idle, i thought it was somewhat normal, and out of nowhere tonight the car started shaking, and it sounds like there is a metal baseball bouncing around in the bellhousing, im guessing it's the throwout bearing, barely got it home
snorf
11-04-2019 06:44 AM
