Do aftermarket shocks fix the clunking - 07 TLS
I still have the dreaded clunking suspension issue. Clearly Acura cannot fix it and it takes a lot away from an otherwise great car.
Thinking of going with the Tokico HTS. Has anyone changed shocks and does that help the clunking issue?
Thanks for your help.
Viraf
Viraf
I just had the same problem. The dealership couldn't figure out for the life of them what the sound was. They told me all kinds of BS (shocks, springs). Brought to my friend's aftermarket shop. It was the linkeage. $36 bucks for each side. Done. No more clunking.
Linkage
If it's only an audible clunk, then check your swaybar endlinks (per above) and your swaybar bushings on the subframe. If the clunk can be felt as instability in the suspension, check your control arm bushings [upper (2) and lower (3..mainly compliance and shock absorber)] and balljoints. My LCA bushings were torn/cracked and would clunk over bumps, which I felt as looseness in the suspension.
SidhuSaaB
May 30, 2020 12:40 AM
vpasla1
Sep 17, 2016 07:24 PM
trinikidcl
Sep 4, 2015 12:56 AM
