CEL won't go off
Old Nov 24, 2010 | 11:42 AM
d-townhakuzo's Avatar
Exclamation CEL won't go off
Hey guys. I installed the P2R throttle body spacer today, and my CEL won't go off now. I know that when you put the AEM V2 on, the CEL is on for a little, then after you drive a little bit, it goes away. Knowing this, I went and drove the car so it would adjust and go away. But after 20 minutes of driving, it wouldn't go away. I plugged back in the only sensor I unplugged. Should I just give it time? Anyone else with this problem?
Old Nov 24, 2010 | 12:14 PM
nfnsquared's Avatar
Not sure, but if it was the MAP sensor you unplugged, I believe it will take a few days to a week for the light to go out. IRRC, the ECM is rebuilding the readiness codes.
Take a look at pg 263 of the owner's manual. I think any disconnected sensor that has inputs to the ECM and is used in the Readiness Code settings will cause a reset/rebuild....
Old Nov 24, 2010 | 01:56 PM
BradE's Avatar
You can unhook the battery for about an hour, then reconnect it. Leaving it unhooked for that long will clear the memory out of the PCM and turn the light off.
Old Nov 24, 2010 | 05:00 PM
Opel's Avatar
pull fuse #8, under hood fuse box..disconnect the battery. Dont have to wait an hr..just do it, and connect it back up.
Old Nov 24, 2010 | 10:48 PM
Thanks guys. The fuse idea worked great!
GWEEDOspeedo
Jan 15, 2016 10:39 PM
ITSJESTER
4G TL Photograph Gallery
Oct 13, 2015 12:53 PM
samson_420
Oct 8, 2015 01:47 AM
hrothgar02
Sep 28, 2015 11:08 AM
mars
Sep 28, 2015 11:03 AM
