DIY - Front Motor Mount
Old Apr 14, 2012 | 02:13 PM
ez12a's Avatar
the overexplainer
Didnt find a DIY for the fronts...so here's what I did this morning. There are different ways to do this, but this is how I did it after reading. I found that removing the two fans gave me a lot more working room. Be careful not to bend too many of the radiator fins. They're as delicate as paper.
Tools:
-Assorted 6 point socket set up to 19mm
-Optional Flex/Swivel Socket or adapter (picked up a 3/8 and 1/2 for $10 at harbor freight. worth it, imo), and magnetic parts grabber
-Various extensions for at least 1'
-torque wrench, ratcheting wrenches.
-small flathead
-needle nose pliers
-flat head screwdriver or honda clip removal tool
-Jack and jack stands, piece of wood
-catch pan
-disposable Shop towels
-sharpie
Fluids:
-Coolant
Step 1:
Remove the Coolant Reservoir bracket, and swing the res out of the way.
2. Disconnect 2P connector to passenger side fan
3. Jack up the car enough to fit stands on the front.
4. Remove all the clips holding the underside plastic and remove it:
5. Undo the 2P connector for the underside of the other fan. Unclip the wiring from the fan with either needlenose pliers or undoing the zip tie with a small flathead.:
6. Undo the 1P Connector attached to the passenger side fan from underneath, and unclip the wiring harness from the fan.:
7. Position catch pan underneath and remove upper radiator hose from the radiator and position it out of the way. A bit of fluid will come out, once it just drips stuff a shop towel in the radiator end.
8. Remove the 4 bolts on the drivers side fan and the 3 bolts on the passenger side fan. Remove passenger side first, then wiggle the drivers side fan out.
9. Jack the engine up slightly with a piece of wood on the oil pan, or enough to support it.
10. 19mm socket: Undo the bolts from the mount as well as the swivel adapter. Use the long extensions to help. Use a sharpie to mark an outline of the mount.
11. Attempt to remove the mount, if it's difficult, jack up the engine a tiny bit and try again. Repeat until you can wiggle it out. dont forget to unhook the vacuum line at the bottom. I used needle nose pliers to gently wiggle it out.
12. After transferring dust cover to the new mount, put new mount in and align it to the marks you made. I found installation to be more difficult than removing, so I jacked the engine up a bit more and was able to get it in. Align the holes, and when putting in the bolts, put the upper left in first. Swivel sockets come in handy at this point, as well as the magnetic parts grabber. I used the magnet to get the bolt into position. I didnt seem to have much trouble at all with the upper left as some other people did. All bolts went in smoothly by hand.
13. Install all the removed parts, and dont forget to top off the coolant and burp the system just in case air got in. Check that all the connectors (3) have been securely connected and the harnesses attached to their mounting points. Make sure you dont have any extra bolts.
Test drive after burping to make sure there's no air.
aaand done. Sorry if it's kind of jumbled. I'm a little tired
Old Apr 14, 2012 | 02:30 PM
ez12a's Avatar
the overexplainer
and picture of old mount...which actually seemed ok after 68k miles. Leaking no fluid. It only looks greasy from the coolant getting all over it.
also a pair of safety glasses never hurt, especially when working with the coolant.
Old Apr 15, 2012 | 10:08 PM
invalidalias's Avatar
nice!!
These are super easy. side especially!
good write up
Old Apr 15, 2012 | 10:32 PM
DeathMetal's Avatar
Fearless DIY Guy
NICE JOB!!!
Any plans on DIYs for the other mounts?
Old Apr 16, 2012 | 12:08 AM
paperboy42190's Avatar
nice. i did all my mounts recently. front and sides were easy....so was the upper transmission mount....now the rear, that was a PITA! lol but i still got it done.
Old Apr 16, 2012 | 12:45 AM
ez12a's Avatar
the overexplainer
thank you, all!
Since my front seemed to be OK I can hopefully assume the rear is good too, but I'll make one when the time comes for sure
I was apprehensive about undoing the radiator hose since I've never worked with bleeding or burping the coolant before..but it wasn't so bad at all.
Hope the documentation of my job can help people in the future!
now...to do or not to do the 105k service myself...
A SiQ TL's Avatar
excellent write up, definitely should be added to the garage.
Old Apr 16, 2012 | 10:57 AM
lusid's Avatar
FTW
Are there suppose to be pictures in the thread? If so they are not loading.. Or is this a text DIY?
Old Apr 16, 2012 | 11:05 AM
lilsid112's Avatar
Pictures are included in the first post. Great write up!
Old Apr 17, 2012 | 11:04 AM
lusid's Avatar
FTW
I guess pictures are blocked at work. Wonder which host he used..
Old Apr 17, 2012 | 11:09 AM
ez12a's Avatar
the overexplainer
dropbox lol..you must have that blocked for sec reasons
Old Apr 17, 2012 | 12:39 PM
flyromeo3's Avatar
i may need to replace my front mount but I want to ask. Is it NECESSARY to remove the radiator hose?
Old Apr 17, 2012 | 12:45 PM
ez12a's Avatar
the overexplainer
as far as I could tell, yes. I couldnt wiggle out the fan otherwise. I tried removing the mount with just the passenger side fan out and it just didnt seem possible without touching the radiator unnecessarily.
You also dont want to struggle too much because you may bend more radiator fins in the process. they're really that fragile.
not a lot of air got into the system just by removing that hose. Angle the hose upwards so the coolant "falls" back into the engine and tuck it out of the way in that upright position.
edit: https://acurazine.com/forums/showthread.php?p=12924083
https://acurazine.com/forums/showthread.php?p=12853692
looks like you can do it without removing the hose or the fans for that matter in the post above. I found it personally to be very difficult, but you can try whichever method you find proper. Unfortunately neither elaborate on just how they did it. They might have pulled it from underneath.
Old Apr 17, 2012 | 01:01 PM
ez12a's Avatar
the overexplainer
edit: first link i posted the guy put up directions for the 2G TL. fail.
i still dont know how speedy did it though lol
Old Apr 19, 2012 | 05:47 PM
UA6's Avatar
UA6
How bad are the vibrations after you installed the new mounts?
Old Apr 19, 2012 | 06:01 PM
ez12a's Avatar
the overexplainer
it honestly didnt change..it must be normal or something else that i think i "feel".
sometimes when i crank the starter, when the engine catches and starts it feels like the engine is twisting. Sometimes it catches and starts smoothly, other times it feels like it catches on the wrong "stroke" or somehow it's off balance and i want to say i hear a thud when it does. I've looked at the engine while it starts and it barely moves if at all. It might just be in my head lol. My dad's E46 with its longitudinal mounted inline 6 you can feel the car rotate slightly from the starting.
i guess the fact that i had to jack the engine up higher to put the new one in indicates the old one was sagging a little. At least i know i'll be good for another 70k at least. I dont get how people have cracked and leaking mounts well before I did in terms of mileage. My side mount was cracked though.
Old Apr 19, 2012 | 06:22 PM
nokkieny's Avatar
I didn't remove anything, you can wiggle it out through the battery side of the engine.
Old Apr 20, 2012 | 12:39 PM
ez12a's Avatar
the overexplainer
if you could take pics next time you do it and add them here or something that would be great i want this thread to be an all inclusive information dump for the front mount!
There's like no real information about it for the 3G other than some anecdotes!
Old Apr 20, 2012 | 12:52 PM
nokkieny's Avatar
I am trying to diagnose a vibration so i might reinstall my front mount if so I will take a picture and put it up. I do believe when I originally did it there was a guide, as I know I couldn't have done it without one.
Old Apr 29, 2012 | 09:54 AM
nokkieny's Avatar
I didnt take pictures, was short on time and had some trouble with the rear left bolt, I had to take the battery out so I could get my breaker bar in level.
I believe I did it the first time without removing the battery, but if I was going to do it again I would remove the battery, it took me about 20 seconds to wiggle it out.
Also, I did not remove the splash guard there is a hole that you can reach your hand through to connect the vac line.
To thread in the rear left bolt it is fairly easy to access from under the car.
Old Jul 18, 2012 | 06:29 PM
BuffBakerGA's Avatar
I was able to get the mount out without removing the radiator or the battery. The only thing I removed was the top radiator hose and the coolant reservoir. Also the back left bolt was easier to thread from the bottom and then tighten from the top...
Old Jul 18, 2012 | 07:15 PM
Old Jul 18, 2012 | 09:07 PM
ez12a's Avatar
the overexplainer
nice job! I didnt remove the rad either, just the upper hose and the fans.
Hopefully this thread will help others get an idea of how to tackle the job. Obviously there are several ways of going about it, but at least we have a dedicated thread.
Old Feb 9, 2013 | 08:49 PM
4drviper's Avatar
I just finished front and side.
for front,
1. only passenger side fan has to be removed but still undo the driver side fan bolts but leave the connectors alone, so you can wiggle it as needed while maneuvering the mount out and in.
(therefore no need to remove the upper hose)
2. put a thin cardboard against radiator to prevent damage
3. my fav tech at local honda dealership told me, the wiggling can be done if engine is raised a little high. undo the side mount bolt, and raise the engine till the hole in the bracket is almost all the way visible. you should have enough room to wiggle the mount out and in
now to do rear tomorrow .. :/
Old Jul 29, 2015 | 04:21 PM
polish_pat's Avatar
Thank you. This was very useful. I changed my front and passenger side mount today. Not sure i want to tackle the rear as it seems to require a lift so I can take it out from below.
Old Jul 30, 2015 | 07:56 AM
DMZ's Avatar
DMZ
Head a da Family
Nice writeup OP. But I took the easy way out by paying Paul (our mechanic in NJ), and I didn't have to rob Peter to do it!
Old Jul 30, 2015 | 08:28 AM
polish_pat's Avatar
The worst part about doing both mounts yesterday was the heat. It was 100 degrees from 10 am to 6pm. I was sweating bullets, but you know what? I saved a lot of money. The dealer quoted me 750$, another repair shop a bit less but with OE parts, in total, it cost me 120$ for the mounts...no question it's worth it.
Old Jul 30, 2015 | 09:52 AM
DMZ's Avatar
DMZ
Head a da Family
Paul's prices are a lot less than the stealership.
Old Jul 30, 2015 | 11:45 AM
polish_pat's Avatar
I live in Canada, and right now, the exchange rate is killing our dollar so a part that costs you 100$ would cost me close to 150$. Also, its a known fact that a dealer is always more expensive...
Old Nov 2, 2015 | 02:29 PM
mazen222's Avatar
i need to change mine as well (Front and side). I remember seeing a sponsor post regarding a new set designed for us that would last longer.
Anyone tested them? are they worth it?
Old Nov 2, 2015 | 02:36 PM
polobunny's Avatar
Registered Bunny
You're thinking of XLR8 mounts. Are they worth it... that's up to you.
https://acurazine.com/forums/perform...08-all-764063/
There's different levels of polyurethane inserts and you want to understand which one applies to you. Some people spring for hard ones and regret it after as it transfers a lot of the vibrations to the cabin in exchange of little engine movement.
Aftermarket mounts are not needed per se, usually replacing completely broken mounts even by OEM ones will make your car feel much nicer than before.
Also hi!
Old Apr 28, 2017 | 12:23 AM
nvasion's Avatar
anyone got updated pics? i plan to do this soon.
Old Jul 14, 2025 | 02:35 PM
4drturbo's Avatar
Same here. There are videos on YouTube. The video that has the most views the guy didn't remove the radiator, fans, or even hoses. I have a type S with ATX so I'm not sure if it's any different. Then say a base with a manual transmission which might have more room.
drone619
Jan 26, 2016 07:09 PM
wilztlxs
Dec 1, 2015 09:16 AM
BKSleeper
Oct 7, 2015 10:20 AM
mossman77
1/2G MDX (2001-2013)
18
Sep 16, 2015 12:21 PM
08 NBP TL
Sep 8, 2015 08:49 PM
