CV Axle Replacement
Old Jan 19, 2021 | 10:18 PM
redxvv's Avatar
Question CV Axle Replacement
Hi guys,
So this is what happened to my front left end the other day while I was driving...
My question is what parts do I need to order to get this into the shop and fixed up? I have a mechanic that's been very good to me and will do work if I bring the parts in and I'm just curious what you guys think I'll need to pick up for everything to get back to normal. It's an 07 with 150xxx km on it and I've been down some rough roads the past couple of years. I'll be heading down to the shop in a couple of days to talk to a mechanic when I have another car available but would love some input. I'm thinking I should order the CV axle assembly for both sides and do then while he's down there as well as tie rods and bushings. Is there other parts I need to get this fixed or just the axle assembly?
Note: For anyone that can see my post history, I've ordered the type S front and rear from Aeroworks and will be putting them on my car this summer so stay tuned for fitment pics!
Old Jan 20, 2021 | 02:31 AM
redbeard1's Avatar
I think you also need the lower ball joint.
Did you cut the lower ball joint to make room for the repair or maybe the lower ball joint failed and that caused the axle to break.
Old Jan 20, 2021 | 07:58 AM
DMZ's Avatar
DMZ
Head a da Family
Order them for both sides. APWI's from rockauto are the way to go.
Old Jan 20, 2021 | 08:04 AM
horseshoez's Avatar
Latent car nut
I second the motion; by far the best axles for the money.
Old Jan 20, 2021 | 03:29 PM
I was thinking this as well when i saw this
Old Jan 20, 2021 | 03:58 PM
whitetiger5's Avatar
wow...I'm still confused how people are able to break their ball joints like this? is it from years of neglecting to replace once they show signs of wear? car doesn't look lowered so it can't be suspension modifications?
Old Jan 20, 2021 | 05:58 PM
subinf's Avatar
One on the right for me
Do both sides. When mine finally failed (driver's side) the other one wasn't too far behind.
Old Jan 20, 2021 | 07:01 PM
redbeard1's Avatar
I just realized there may be damage to the knuckle area (see image below). If you could take a picture of the knuckle, we might be able to tell you what else looks damaged. A close-up picture of the area that holds the lower ball joint (circled in red) might also be helpful.
Here is a link to a youtube video. The accord seems to have had a similar problem.
Old Jan 21, 2021 | 10:15 AM
redxvv's Avatar
Thanks for the help guys. I've only had the vehicle for about 2 years now and I am the second owner. I have no idea how this happened but was planning on replacing outer tie rods and lower ball joints before this happened. I will be ordering the CV axles for both sides. The car is parked outside on some jacks so I'll try to get some extra photos as well. There haven't been any suspension modifications but hopefully I can get her back up and running soon.
Old Jan 21, 2021 | 10:34 AM
redxvv's Avatar
So here's some photos I got. It looks like the lower ball joint failed and that's what caused the CV axle failure. Anything else I should add to my shopping list? Possibly replacing the front wheel bearings while I'm there?
https://imgur.com/a/ktAG7VW
Old Jan 21, 2021 | 10:58 AM
Make sure you get OEM ball joints! No Moog!
https://acurazine.com/forums/3g-tl-t...beware-805131/
Old Jan 21, 2021 | 11:00 AM
redxvv's Avatar
I've already got a set of ACDelco's I was going to put in just before this accident happened. Hopefully they don't have problems like the Moog ball joints have been reported to have.
Old Jan 28, 2021 | 01:16 PM
DMZ's Avatar
DMZ
Head a da Family
[QUOTE=thoiboi;16682249]Make sure you get OEM/QUOTE]
I have Moog ball joins running several years now without any problems.
DevonK
Jan 25, 2021 12:25 PM
purple3.0haze
1G CL Problems & Fixes
14
Jun 6, 2010 02:10 PM
peters_sweet_CL
Aug 27, 2009 11:16 PM
TSXGOTME
Oct 13, 2008 02:15 PM
D73
Aug 29, 2002 10:42 AM
