Cruise control not working??
Old 02-20-2009, 11:11 AM
04 "NBP TL" 6mt
CHiNaMaN440's Avatar
Ealier this week, my cruise control stopped working when I tried using it. When I press the button, it illuminates on the gauge cluster. But when I try setting it, nothing happens.
Any ideas?
Old 02-20-2009, 11:14 AM
RACINGHART03's Avatar
Had any work done on your car recently? Do your brake lights work?
Old 02-20-2009, 11:18 AM
04 "NBP TL" 6mt
ummm I did the accord fog light mod Tuesday. But it stopped working Monday
I have to check if my brake lights are working or not
Old 02-20-2009, 11:20 AM
04 "NBP TL" 6mt
I forgot I swapped out my base tails for type s tails Sunday. But that's pretty much plug and play
Old 02-20-2009, 11:25 AM
Basically the light on the dash tells you the system is ready. Its the input from the "set" switch that activates it. The brake light circuit plays a role though which is why I ask.
Old 02-20-2009, 11:27 AM
04 "NBP TL" 6mt
ok, so what do I need to do? check my fuses?
Old 02-20-2009, 11:48 AM
If the brake lights dont work its a good place to start. Still gathering info.
Old 02-20-2009, 12:05 PM
04 "NBP TL" 6mt
ok, I just checked my brake lights and looks like there all working.
Any other ideas?
Old 02-20-2009, 12:34 PM
Any work performed on the car other than what you did?
Old 02-20-2009, 03:03 PM
Fulani has a TL's Avatar
I remember I had a similar problem when I installed gas and brake pedals from SuperComputers. My cruise would set, and then would randomly disengage. It took a few days and then it stopped doing that. Possible some pressure being applied to the gas pedal?
Old 02-20-2009, 03:20 PM
Totally understandable. The cruise will not turn on/disengage if it detects the slightest ON signal from the brake switch. The weight of the brake pedal was probably pulling it down the slightest bit which would prevent the cc from setting or causing it to cancel. Good post by the way. Just made me realize I should have suggested to the OP to adjust his brake switch. So there. Do that.
Old 02-20-2009, 11:17 PM
04 "NBP TL" 6mt
I did, nothing
any other ideas on what it could be?
Old 02-21-2009, 07:52 AM
Yes try and adjusting your brake pedal switch. Its an easy DIY.
Old 07-13-2009, 05:45 AM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
Received 1,651 Likes on 1,116 Posts
I have an Accord, but the same problem still applies.
I have a slightly different problem. The Cruise Control light is on, telling me the system is armed and ready to be set. Whenever I press the set button, nothing happens. The "Cruise" does not come on, the cruise control does not set, etc. The brake lights all come on, and the fuses are all OK.
I don't understand what happened. It just went out. I have done no work to my car in a long time.
Old 07-13-2009, 10:23 AM
zsameer's Avatar
Maye be you crimped your led unit wires while running them through the housing. might want to check since i had a cruise problem caused by that.
https://acurazine.com/forums/3g-tl-problems-fixes-114/cruise-control-issue-733926/
Old 07-13-2009, 12:04 PM
Chapter Leader
(Northeast Florida)
gatrhumpy's Avatar
https://acurazine.com/forums/showthread.php?t=733926
BTW, my cruise decided to bless me by working again. That was weird...
Old 10-13-2010, 10:12 AM
Parcus's Avatar
I cannot get my cruise control master switch to engage. When I press it and hold it in it works perfect, but the second I let go it turns off. Is there an easy way to replace this switch. The dealer is telling me it will cost over $240 labor because of the airbag.
Old 10-13-2010, 11:58 AM
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
It's probably a bad switch. It's been known to fail.
You can do it yourself, but you'll need a Torx T30 bit and a 3/8" driver/ratchet. Look in the 3G Service Department under "lighting". There are scans on how to remove the airbag. Basically, it's just two Torx T30 screws, but they can be tough to remove if you don't use the appropriate sized ratchet because they are held in with Loctite. That's the reason you need a 3/8" driver/ratchet. Don't use a 1/4" ratchet.
If you're the least bit mechanically inclined, don't pay the dealer to do this...the switch only costs about $55. Contact Kaleb at Prestige Acura (use the Vendor link at the top of the page) to order the part.
Edit: Here's a couple of links:
https://acurazine.com/forums/3g-tl-2004-2008-93/steering-wheel-switches-cruise-radio-air-bag-removal-3g-garage-f-160-a-606220/
https://acurazine.com/forums/3g-tl-2004-2008-93/f-168-steering-wheel-removal-763962/
Old 06-11-2016, 08:05 AM
Cold Business
SocomM4's Avatar
Since this is the first thing Google pops up for cc not working, thought id post quickly about my experience. .
Mine isn't working, while driving I armed the system and put my foot under the brake pedal and pulled it towards me. It didn't feel like it moved at all, but was enough that I was able to set my CC. Worked as normal until I stopped pulling the pedal.
Do this before you rip apart your steering wheel.
I got 28 mpg yesterday over an 80 mile trip.
rockyboy
12-06-2022 02:29 PM
peti1212
ILX
22
01-05-2022 05:14 PM
cycdaniel
12-17-2019 10:58 AM
acurajj
09-19-2015 03:47 PM
spoiler900
5G TLX Photograph Gallery
09-11-2015 09:39 PM
Quick Reply: Cruise control not working??
