Cross-threaded Brembo Bleeder
Old 05-15-2012, 12:24 PM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
So I went to bleed my brakes after slightly running out of Motul the last time and I noticed a small leak in the front drivers side top rear bleeder. It's a very small leak. Came to find out it's cross threaded.
Now I ordered two new bleeders just in case. Does anyone know what size the "bolt" of the bleeder is so I can go grab a tap for it? Is it just a 10mm? M10x1.0?
Any tips and or hints?
Old 05-15-2012, 12:34 PM
rockstar143's Avatar
Received 20,014 Likes on 14,518 Posts
let your dog reset your ecu
justnspace (05-15-2012)
Old 05-15-2012, 12:35 PM
Received 16,267 Likes on 11,974 Posts
snot is still coming out of my nose.
and i see what you did there, rockstar...."cross threaded"
Old 05-15-2012, 12:36 PM
LOL...Justin, that actually came from him. Login to you know what...you'll see.
maharajamd's Avatar
^Twas my own joke. If you were somewhere instead of not being somewhere you would have known that... :P
Edit: Assholes.
Old 05-15-2012, 05:21 PM
ha ha...
dude, what did you end up stripping...the threads on the bleeder screw, or the threading on the caliper itself?!
Old 05-15-2012, 06:03 PM
maharajamd's Avatar
^I assume the threads on the caliper as, like I told you today, the calipers are very very soft.
I bought two new bleeders just in case it actually is the bleeder itself.
Old 05-15-2012, 06:43 PM
don't be getting a "tone" with me, boy...was just trying to help you mentally troubleshoot it is all...
I would be doubly safe and order a cheap titanium tap and die set from amazon and be ready to retap...or, why not just pull the current bleeder out now and check the threads!?!? Mabye you can just carefully rethread and throw a little silicone on it to prevent any seepage.
Old 05-15-2012, 08:53 PM
Wiggy Wiggy Wiggy
powerflow's Avatar
The brembo caliper is aluminum, its probably the caliper side threads that are damaged. Your chances are slim, as far as chasing the aluminum caliper threads successfully.
Centric specs out the bleeder size in this post.
https://acurazine.com/forums/3g-tl-problems-fixes-114/help-stripped-bolt-thread-brembo-caliper-849759/
Old 05-16-2012, 06:38 AM
gideon's_test's Avatar
I bled my brakes two weeks ago and a few days ago I noticed a bit of fluid at the base of the bleeder screw also. I plan to try some teflon tape...
Old 05-16-2012, 08:48 AM
how far out are you guys unscrewing to bleed?!? I only do about 1 revolution!
Old 05-16-2012, 09:22 AM
maharajamd's Avatar
^Too far obviously.
With how bleeders work I think if I retap it and can get it to screw all the way in, even if the threads are iffy, it will still work. You know..the seat and all.
I'll try teflon as a last resort.
Old 05-16-2012, 09:38 AM
Chad...try the teflon first!
smarty pants...
Old 05-16-2012, 09:49 AM
the overexplainer
ez12a's Avatar
in my experience when you bleed, some fluid will come out around the threads. This is normal. It's also normal for it to "weep" the residual fluid inside the bleeder once you close it up.
Just got to make sure you rinse it off well when you're done otherwise you'll have a streak of bubbled paint down your caliper. Happened to me and a few others. But after that's all done weeping it's all dry.
gideon's_test (05-18-2012)
Old 05-16-2012, 11:05 AM
maharajamd's Avatar
^Oh it's beyond that for the caliper paint. That's why I need to take care of this before I repaint them. Lol
Old 05-18-2012, 06:41 AM
This describes my situation exactly...And I even have the streak of bubbled paint...
Old 05-18-2012, 08:19 AM
Repaint them badboys then...
Old 05-18-2012, 09:26 AM
maharajamd's Avatar
I will. I don't have a place to word other then at my Moms house. And that, I'm afraid, has/is a planned event.
Once I get a house my modding will go up three fold. As will my paints bling.
Old 05-18-2012, 10:14 AM
#1 Super Guy!
94eg!'s Avatar
Ditto! Drivers outside bleeder too. BOOOOOOO!
And I even washed the shit out of the bleeders when I was done. Twice even cause I saw a little more fluid on that one after. Remember, the hollow bleeder itself is still full of brake fluid when you put the cap back on.
polish_pat
09-30-2015 12:22 PM
Lucrativesoldier
09-28-2015 03:47 PM
2ManyHobbies
09-24-2015 09:23 PM
cacheflowe
09-14-2015 10:35 AM
jmoney2001
09-11-2015 12:07 PM
Quick Reply: Cross-threaded Brembo Bleeder
