Creaking Noise When Turning slow - Suspension Help
Old Mar 25, 2019 | 08:13 AM
Medinak12's Avatar
Need some advice guys. I recently upgraded to tein basis coilovers, skunk2 uppers, replaced driver side ball joint and lower control arms. Replaced sway bar bushings. Alignment is almost perfect. Rides great but I can’t seem to get rid of this creaking noise that started once I added the camber kit. Wondering if it can be the rack and pinion and needs to be totally replaced or if it’s something else? Posting video of the. Noise that happens when turning from a stop or slow turn.
Old Apr 2, 2019 | 10:59 AM
LoveMyTL-S's Avatar
Video?
Old Apr 4, 2019 | 05:04 PM
Medinak12's Avatar
Originally Posted by LoveMyTL-S
Video?
Old Apr 7, 2019 | 01:57 PM
New2meTL88's Avatar
My 08 type s also does this, I've read through some threads and its sounding like a binding rack and pinion. I'm changing all of my transmission switches and mounts along with my motor mounts. I'll keep you updated as to whether that helps or not. I've heard bad mounts can make alot of funky noises
Old Apr 14, 2019 | 09:16 AM
Medinak12's Avatar
ok cool. Yea I thought it was that too but my steeering is fine and not tight at all. No issues whatsoever with the steering. I’m going to have my mechanic take apart the front coilover to see if it’s the top hat or any bushing and also check the driver mount
Actl1
1G TL Problems & Fixes
Mar 23, 2018 01:36 PM
t0talacuratl
Jan 13, 2017 12:27 PM
Abe_Froman
May 26, 2015 09:37 PM
mav238
1G RDX Problems & Fixes
Jan 23, 2014 11:36 PM
ohreallywhat
Mar 5, 2013 09:46 AM
