CREAKING? Fixes....
Old Jul 22, 2005 | 05:42 PM
jich505's Avatar
CREAKING? Fixes....
I have recently started to get a lot of creaking that comes from the driver and passenger door, where the window meets the top of the door. Everytime I drive i get it, the second I crack the window a bit it goes away. So I know that it is just rubbing on the rubber or something. I don't have a lot of faith in the dealer at this point - they will probably say they cannot duplicate the problem...yadayada.
Does anyone else have this problem?
ANY SUGGESTIONS????????? PLEASE HELLLLPPPPPP?????
Old Jul 22, 2005 | 10:47 PM
yard7man's Avatar
Thumbs up
This should help, I started having the problem in Feb. when the weather was cold then it went away then came back when the weather got real warm in June. I had good results by cleaning the rubber seals at the top and sides of the windows with silicone lube. I beleive the rubber seals are drying out and making the noise when the rub against the window when the road get rough. This explains why it goes away if you roll down the window.
Old Jul 23, 2005 | 01:50 AM
jich505's Avatar
Thanks for the suggestion. I was going to go to the lengths of putting a lubricant like vaseline on the edge of the window just to prevent the creaking noise. But I figured this would cause quite a mess when the windows were down.
Is there a special cleaner that you could suggest that I use to clean this rubber. I don't want it to dry it out more and am hoping that it can help prevent the problem for a longer period of time.
Thanks for the help - any othre suggestions, keep them coming!!
Old Jul 23, 2005 | 03:51 AM
ediddy's Avatar
ediddy
Since you are from OC, LA.....South Bay Acura in Torrance has awesome customer service call jon martin if you have any issues with the car they are great in taking care of problems if you get any......310-539-3636.....good luck
Old Jul 24, 2005 | 02:40 AM
jich505's Avatar
Ediddy,
Thanks for the 411!!! I will definitely give him a try and hope he can help me out. Much appreciated.
Dunnik
Sep 14, 2015 02:56 AM
paulff3
Jul 21, 2008 04:23 PM
aznboi2424
Jul 9, 2007 03:45 PM
LIPPSTUH
Mar 12, 2007 10:03 AM
Technique
Mar 12, 2001 01:52 AM
