Cracked headlight
Cracked headlight
Sooo there is a crack somewhere in my headlight and it's filled with fog and water... Was told I have to replace it. This is gonna be expensive af 😢. Did anyone else have the same problem and if so, how much did u pay to fix it???
You can 'fix' it by finding the crack and then filling it with silicone, unless the crack is somewhere on the exterior, then your only fix is to replace it.
Yea, apparently it is a crack somewhere on the exterior and it looks so bad. I guess I have no choice. Also its so hard to remove the headlight out of the 3g TL
perfect time to get you some of these:
https://www.ebay.com/itm/Black-2004-...cAAOSwTitbvr5g
the R&R isn't too bad; see here:
https://acurazine.com/forums/third-g...ics%5D-974372/
Acurafan86
05-12-2014 11:16 PM
stillwaterd
11-20-2005 06:37 PM
