Couple issues after doing complete brake job on a 6MT TL
Old May 27, 2010 | 09:19 PM
TL6SPD's Avatar
Veeeee Tec
Hello, All.
I installed Powerslot Slotted Rotors and Hawk HPS pads on my 2004 6MT. The front are fine and with no issues. The rear make a " chu chu chu chu sound" while driving... maybe they have just not settled in yet?
My biggest concern is that my E-brake does not hold at all and is very easy to pull up. I did a quick look and i think the spring came off. Any suggestions or feedback how to tighten the E-brake?
Thank you.
Old May 27, 2010 | 09:26 PM
AMUA6's Avatar
ScoobyZINE
Not sure on how to tighten it, but how were the pads when you replaced the rotors?
Old May 27, 2010 | 09:29 PM
yungstef's Avatar
8th Gear
oh man,, i think someone needs to take a trip to the shop lol
Old May 27, 2010 | 09:34 PM
csmeance's Avatar
you have to readjust the e-brake after a brake job! Check out the 3G garage on the service manual scans on how to adjust it!
https://acurazine.com/forums/3g-tl-2004-2008-93/brakes-caliper-o-h-pad-repl-hoses-bleed-disc-specs-park-brake-adj-3g-garage-d-041-a-578017/
Scroll down to Page 19-8 for the instructions.
Old May 27, 2010 | 09:39 PM
nfnsquared's Avatar
For the rear sound, did the pads have 3 knobs on them? If so, you need to file off the middle knob:
https://acurazine.com/forums/showpos...3&postcount=32
For the e-brake, you might need to do a major and/or minor adjustment:
https://acurazine.com/forums/showpos...3&postcount=22
Did you use the service manual or one of the DIYs in the 3G Garage?
Old May 27, 2010 | 09:45 PM
TL6SPD's Avatar
Veeeee Tec
Thanks guys!
I will re-check the pads tomorrow for the knobs and adjust the parking brake.
I think there wasn't a 3rd knob and maybe they just need to settle in.
Ive did brake installs in several cars.. including my 6MT CL and never re-adjusted the parking brake. It worked fine and there were no sounds.. That sound is soo annoying.
Old May 27, 2010 | 10:02 PM
nfnsquared's Avatar
Did you turn the p-brake sprocket wheel to get the rotor off?
Old May 28, 2010 | 12:38 AM
Hi speed's Avatar
runnin a little boost
There is a little slot on the back of the rear brakes to adjust the ebrake. The TL uses a drum style brake for the ebrake and it's adjusted just like old school drum brakes. You should be able to do it with a screw driver, you just have to figure out the direction to turn the knob.
mada51589
Jan 9, 2025 04:40 PM
HOWELLiNC
Sep 10, 2015 01:39 PM
asahrts
Sep 4, 2015 05:55 PM
nishant11
Sep 2, 2015 10:34 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
