coolant temperature
Old Mar 15, 2022 | 02:55 AM
plantac1's Avatar
coolant temperature
can l ask something?
I want to ask you the 2007 acura tl type-s . The cooling water temperature went up to 215F. Isn't 203F normal?
Old Mar 15, 2022 | 09:01 AM
peter6's Avatar
OEM thermostat should begin to open at 169-176°F and be fully open at 194° F. Ideally engine should have 194° F then. If coolant temp is above 206 °F both fans should run on high.
If it went above that and car wasn't in some really heavy load scenario (like going uphill in hot environment or race track or towing) then I would assume something isn't right. If coolant level ok then I would replace thermostat first. Also could make sure that cooling fans are working. There might be other issues but those two are probably most common.
Old Mar 15, 2022 | 01:27 PM
csmeance's Avatar
make sure all air is out of the system first by burping cooling system with heat on full
rah11h
Oct 2, 2022 01:35 PM
Justin Bell
Oct 13, 2020 07:54 PM
Jason Holt
2G CL Problems & Fixes
Oct 25, 2019 04:38 PM
taiwoato
1G RDX (2007-2012)
Jun 21, 2019 07:35 PM
dannyb22
Nov 8, 2009 11:10 PM
