How Much Coolant?
Old Nov 14, 2014 | 10:46 AM
rah11h's Avatar
How Much Coolant?
Am going to flush my coolant system in my 2007 tl. Was going to dealer to get coolant. Do I need 1 or 2 gallons of coolant. Only want to make one trip. Thanks.
Old Nov 14, 2014 | 11:24 AM
mfrench13's Avatar
From the quick google search I just did, it looks like you will need at least 2 gal
Old Nov 14, 2014 | 11:34 AM
BukvaMan's Avatar
Radiator drain and fill would be 1 gallon.
Old Nov 14, 2014 | 11:25 PM
JMiles_T's Avatar
2.2 gallons
Old Nov 15, 2014 | 04:31 AM
paperboy42190's Avatar
2 was enough for me when I flushed my coolant
Old Nov 15, 2014 | 04:34 AM
nfnsquared's Avatar
Originally Posted by rah11h
Am going to flush my coolant system in my 2007 tl. ...
Why?
Old Jan 8, 2020 | 04:20 PM
Chad05TL's Avatar
Did you all also drain the coolant from the rear of the engine block, as well as the bottom of the radiator?
I am not sure why they say "after engine overhaul"..
Old Oct 2, 2022 | 01:35 PM
LazLong's Avatar
N00b Extraordinaire
After overhaul
The "after overhaul" refers to a completely dry engine I believe. When you drain coolant by just opening the radiator drain cock, not all of the coolant drains; some is left in the block.
I don't know if the J32A3 has block draining bolts like some engines.
VictorTL
Nov 14, 2018 12:30 PM
marky11707
Nov 30, 2009 01:12 AM
Mandy
1G TL (1996-1998)
Feb 11, 2009 11:26 PM
49er
Oct 8, 2006 01:00 AM
