Code P0717?????
Old Jul 18, 2016 | 04:07 PM
Edwin Martinez's Avatar
Code P0717?????
I just replaced the starter that went out.
But after 2 block I got flashing/blinking "D" light, VSA light, & Check Engine.
So I drove to the O'Reilys and had them run a scan code.
I got code P0717.
Old Jul 19, 2016 | 06:20 AM
Turbonut's Avatar
P0717 P0717
Problem in Mainshaft http://www.autopartswarehouse.com/search/?Ntt=speed+sensor Circuit (No Signal Input)
Not overly familiar with the code, but most corrected the code by replacing
the sensor, but since you replaced the starter, I'd check the wiring/connection.
acurazine.com/forums/3g-tl-problems-fixes-114/p0717-transmission-while-driving-897813/
Old Jul 19, 2016 | 12:10 PM
Thanks for the reply bro.
But i moved all the stuff, found out where the sensor is and it ended up all cracked from when i replaced the starter.
Must of been when I dropped my wrench,
I tried pulling it out and it the plastic just fill into pieces.
Originally Posted by Turbonut
P0717 Problem in Mainshaft Speed Sensor Circuit (No Signal Input)
Old Jul 20, 2016 | 07:48 AM
Turbonut's Avatar
Glad it was an easy fix.
Sturmgewehr44
Sep 13, 2016 05:08 PM
hypelink
Aug 14, 2016 12:10 PM
SocomM4
Jul 11, 2016 09:18 PM
E39
Feb 9, 2016 01:12 PM
gasman65
Jan 25, 2016 05:56 PM
