Changed battery radio code wont work
Old Feb 5, 2016 | 08:31 AM
E39's Avatar
E39
I pulled radio and navi codes from acuras website after disconnecting battery. Navi code works but radio code keeps giving me a error message and doesn't work. I tried inputting the code in a parking garage and also in a underwater tunnel with no luck.
Old Feb 5, 2016 | 01:57 PM
EarlThePearl's Avatar
Holla At Ya Boy
Try using this thread to help you enter your radio code.
https://acurazine.com/forums/problem...g-code-809775/
Old Feb 5, 2016 | 05:04 PM
E39's Avatar
E39
My problem isnt that my car wont ask for a code. It asks for a code but when I enter my code it reads it as if I am entering the wrong code.
Old Feb 8, 2016 | 03:54 PM
KCee's Avatar
I had this same problem and had to pull a fuse to get it to reset. Don't recall which fuse though, but maybe you can Google it.
Old Feb 8, 2016 | 05:55 PM
pohljm's Avatar
sounds like a bad code. sometimes the code is written in the owners manual and also on a sticker in the glovebox. an underwater tunnel huh?
Old Feb 8, 2016 | 09:51 PM
nfnsquared's Avatar
OP, you are using the radio preset keys to enter the radio code, correct?
And the radio code you got from the Acura website is 5-digits, correct?
Old Feb 9, 2016 | 12:55 PM
E39's Avatar
E39
Lmao that sounded funny to me also as I was typing it.
Old Feb 9, 2016 | 01:12 PM
E39's Avatar
E39
Thanks for the help guys, I figured it out. It turned out that the device serial code I was using was for the nav unit and although acuras code retrieval website was giving me 2 separate codes, 1 four digit code for the nav and 1 five digit code for what I presumed was the radio, the 5 digit code would not work. What solved the problem was holding down 1 and 6 on the radio preset buttons and pressing the power button. That gave me the serial number for the radio itself which gets displayed on the small info screen above the nav. I then entered that serial number in acuras website and was able to retrieve the right code.
STL acura
May 7, 2017 03:24 PM
