Clutch and Flywheel Replacement
Old Nov 2, 2011 | 02:25 PM
duggan419's Avatar
This is one of those live and learn life lessons....
Noticed the rpms revving high before the car accelerated when I had a rode trip to Maine way back in the beginning of July (Car has 101k miles now). Problem got worse and worse and I finally decided to call a shop and get the clutch replaced or master or slave cylinders replaced in order to drive the car properly.....waited too long. It popped out of gear on the highway and wouldn't shift back in to any gear and I had to get it towed to a shop.
Flywheel heat scaring and pressure plate and clutch assembley destroyed....just thought I would let you guys know prices for this whole assembly to be fixed:
Flywheel (Acura) - $696.00
Clutch Kit - $590.00
Labor - $680
Couple other misc costs plus tax and my wallet took a hit of $2162.76.
Just a lesson to all those out there, if your clutch starts slipping take it in, do NOT push it....because you will destroy your flywheel and these Acura/Hondas have the special type flywheel that can not be turned down ythey have to be replaced.
Happy Driving.....
Old Nov 2, 2011 | 02:28 PM
sorry to hear.
i bought my clutch kit from acuraoemparts.com for about $250
i didnt have to get a flywheel, but from the same source its about $450.
I had a local mechanic install the clutch for $400.
Old Nov 2, 2011 | 04:18 PM
ez12a's Avatar
the overexplainer
Holy crap, but that still isnt as bad as rebuilding my family's Odyssey automatic transmission that fried itself. Total bill with 2 year warranty was 2800. Mind you, this is the second time it has been replaced. First one lasted 60k, then replaced by Honda under recall/ext. warranty, now this one just recently at ~120k.
I'll take the $2162 for what i'd say is a fairly major repair. For no reason should you be rebuilding the internal gearbox anyway in a 6MT for the life of the car unless your 3rd gear gets unusable.
Be glad you dont have the 5AT.
Old Nov 2, 2011 | 09:30 PM
SouthernBoy's Avatar
Registered Member
Labor - $680
Happy Driving.....
Our flywheels are dual mass units. Only 101,000 miles on the clutch? Did you buy the car used? That's not a lot of mileage on a clutch. Sorry you had this happen to you.
Old Nov 3, 2011 | 05:06 AM
duggan419's Avatar
Yeah I bought the car used with 48k miles....from all my reading in the forums and postings online I've read that the clutch will go on these cars. (It was still the original clutch).
If I'm justifying the cost......I have literally only changed the oil and maintained proper fluid levels for 50k miles on this car. 2011 however was a different story....bad ignition coil, did the 105k maintenace (water pump, timing belt tensioner) and now the clutch and flywheel (which was my fault for being ignorant). So almost 60k miles on a car and $3300 in maintenace and fixes. I really can't be angry with that.
Plus....my drive in to work this morning was sooooo much fun. Made me remember why I love this car so much. Stay thirsty my friends....
Old Nov 4, 2011 | 07:38 AM
Registered Member
A clutch can go on out any car. However if nothing is wrong with it from the start, you should never have to replace it during the normal life of the car (assuming 200,000 to 300,00o miles - most people never put that many miles on a car before they trade or sell it).
Taking things from a new car, assuming the clutch is well designed for the car, the installation was done correctly, and there are no potentially weak parts used in its production, the only other factor in the life of the clutch is the operator. And this by far is the weak link. Operated properly, a clutch should last you as long as you own your car (this precludes towing, racing, or some other extraordinary factor in the mix). Under "normal" conditions and driving factors, if an original owner has to replace a clutch after only, say, 75,000 miles or so, he is doing something VERY wrong. So 48,000 miles is nothing to a clutch operated correctly. And unfortunately for you, you most likely have no clue how the previous owner(s) operated that car.
Old Nov 4, 2011 | 08:39 AM
^agreed. somewhere in that clutches life it was operated incorrectly.
Old Nov 18, 2011 | 02:32 AM
robocam's Avatar
I thought you had to replace the flywheel anyway during a clutch replacement. I was just told yesterday that I need a new clutch, and I was quoted $1880. I asked if the flywheel was included, and he said "yes, they will machine it," but I said, "parts told me it can't be machined." He looked into it and apologized for the misquote and gave me a discount. The flywheel costs $677, so if you add that to $1880, it comes out to $2557, but with the discount, the new quote is $2100 + tax.
Labor - $680
Happy Driving.....
Old Jan 18, 2012 | 01:26 PM
StreetKA's Avatar
Just to give u heads up i paid $760 for complete clutch kit(flywheel, disc, pp, bearings and rear main seal)
Old Jan 18, 2012 | 01:39 PM
robocam's Avatar
Thanks. Was that at an Acura dealer?
Old Jan 18, 2012 | 08:32 PM
bluetl04's Avatar
Duggan419....hey man, what dealer did you go to?...im in CT too and need to replace my clutch
Old Feb 14, 2013 | 05:24 PM
jprows's Avatar
'05 TL 6MT Navi
Does anyone know if LUK DMF063 will work well in an '05 TL? I know that part is supposedly for the '03 CL but it's $70 cheaper on carolinaclutch.com right now AND there is a blerb on the 062 page that says "Special Notes: can use DMF063" I need to order a new one right away - my car is on racks at Honda with a technician waiting for me to order the part FML lol. Any input is great. TIA
Jeff
cobra10363
Jul 23, 2024 04:13 PM
niray9
Dec 8, 2015 07:34 PM
mugen_kid
Nov 13, 2015 10:38 PM
Sep 15, 2015 06:44 PM
heyitsvic
Sep 4, 2015 09:38 AM
