Climate control issue
Old May 29, 2011 | 10:07 AM
Mattgtp's Avatar
06 6mt A-Spec Navi
Hey I searched for the same problem and found some similar but could find any solutions. My 06 recently has started not to blow any different temperature from the climate control on all setting unless I change it to "HI". Even at 31 degrees(thats the last setting before "Hi") it will blow cold air. The fan still adjusts its speed and it changes the setting for the air distribution but no change in temperature. If I turn the temp up all the way and then back down it seems to work almost normal with the temperatures being off by a bit. Also last sumer I noticed if I ran the a/c i would need to set it at 25 or 27 degrees otherwise it would be way to cold, guess thats when the problem started. Previously I would run 22-23 degrees.
Any help where to start to look would be appreciated
Old May 29, 2011 | 09:40 PM
mikedog4's Avatar
Why me??
check the charge on the a/c. a lot of hondas with dual zone climate controls will blow like that if the charge is low.
Old May 30, 2011 | 08:16 PM
Mattgtp's Avatar
06 6mt A-Spec Navi
the problem happens even when im not running the a/c just the outside air. So far this year I have not needed the a/c its been so cold up here.
Old May 31, 2011 | 12:09 PM
mikedog4's Avatar
Why me??
regardless of set temp if you run full auto mode then the a/c kicks on and off as needed, thus could still be a charge issue.
Old May 31, 2011 | 02:18 PM
jda123's Avatar
Dogmatic Dinosaur
Make sure that your temp sensor is installed right. It is in the lower part of the dash where you right knee would be. Mine got detached and was reading the temp up under the dash rather than in the car. Once I reattached it, it works fine.
If you search for some iSimple install threads, you have to remove the lower panel and temp sensor to accomplish that job.
Old Jul 4, 2011 | 05:57 PM
Mattgtp's Avatar
06 6mt A-Spec Navi
Installed new interior temp sensor and problem solved. The old one had so much dust and debris clogging it up its no wonder it couldn't get a good reading. I also replaced the outside temp sensor because it would read 19 degrees for about an hour of the car running then finally move to the correct temp. Works great now
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
lovic87
Sep 15, 2015 06:07 PM
PortlandRL
Sep 14, 2015 12:01 PM
