Clicking speedometer while car is off.
Old Apr 10, 2013 | 09:19 PM
HKAcura's Avatar
This is my first time writing here, I am a female and I dont know much about cars and was wondering if anyone has had the same problem. I had just bought a 2005 acura tl and noticed when I shut off the car the speedometer clicks every minute or every other minute, which will cause the battery to die if I don't use it everyday.
Can someone please tell me what it can possibly be, maybe I can make suggestions when I take to the dealer so they can check it. I took it to acura today but they couldn't find anything
Old Apr 10, 2013 | 09:30 PM
Noober's Avatar
That is the first time I've ever heard of this problem.
I tried to research it for you, but came up with nothing.
Hope someone can help.
A/S/L ?
Old Apr 10, 2013 | 09:50 PM
rossv1's Avatar
Nudez?
Never heard of the problem. Maybe try disconnecting the battery for like 30 minutes?
Old Apr 10, 2013 | 11:32 PM
Will Y.'s Avatar
Registered but harmless
Originally Posted by HKAcura
...when I shut off the car the speedometer clicks every minute or every other minute, which will cause the battery to die if I don't use it everyday.
The speedometer should be off when you shut off the car.
However, the HFL--Bluetooth unit-- was designed to stay active for 30 minutes after the ignition is shut off, before powering down. Enough HFL units failed to shut down that Acura has a Technical Service Bulletin on replacing the HFL if it remains powered up more than 30 minutes after ignition shut-off. The HFL unit is between the sunroof switch and the rear view mirror mount-- check to see if you're hearing clicking from there.
Welcome to AZ.
Old Apr 11, 2013 | 12:44 AM
HKAcura's Avatar
My husband looked at it and said its the needle on the speed gauge only that jumps a lil and goes back down every 30sec-1min when the car is off no keys in ignition and only when the door is closed. It won't do that if door is open. Please, thanks in advance
Old Apr 11, 2013 | 04:41 AM
paperboy42190's Avatar
Weirdest problem I ever heard of... Got a video of it in action?
Old Dec 26, 2013 | 11:46 AM
Velocity350's Avatar
I am having the same problem on my 2006 TL. While sitting in the car with the ignition off the speedometer gauge drops below zero and ticks back up every 30 to 50 seconds. Does anyone know what might be causing this and if there are any problems that this might cause? Btw I'm a new member and I think this site is great! All of the info posted by users has helped me a lot with my new acura, thanks!
Old Dec 26, 2013 | 01:54 PM
eastcoastguy's Avatar
Same issue! https://acurazine.com/forums/3g-tl-problems-fixes-114/please-help-why-does-my-speedometer-needle-twitch-887701/
No one has ever found the issue or cause of this??
Old Jan 10, 2014 | 02:18 PM
kwb's Avatar
kwb
I had this problem on my 05. I'd turn the car off, the gauge would go nuts and I'd hear all this clicking under the drivers side dash. The alarm also would just start going off at random times for no reason. I checked the battery and it was good.
I ended up having to get a new windshield put in due to a crack. The guy who replaced it said the previous windshield was barely even sealed and had all sorts of leaks. Once the new windshield was put in, the problem just magically disappeared.
I'm not saying that is the problem but I just thought I'd share my experience.
Old Feb 20, 2014 | 08:08 PM
Biggyrat's Avatar
4th Gear
Guage twitching solved
Will Y was on the right track with the post about the bluetooth module. After doing more research on this problem it seems that the module problem is very common on these cars. It continues to draw current from the battery and eventually the car won't start. Check the area where the garage door opener buttons are, in front of the map lights. The front left corner may feel warm. This is a sure indication that the module is not powering down. It is very easy to get to and disconnect. Even if it is not warm you may want to try disconnecting it to see if it solves your problem. I don't know why it makes the gauges twitch, but it stopped when I disconnected the one on my TL.
I was a mechanic for over 30yrs and I would never have suspected that to be related.
I found this link on how to disassemble and get to the module.
/tsb/3gTL/b05-020.pdf
Old Feb 20, 2014 | 08:10 PM
Biggyrat's Avatar
4th Gear
The link didn't post properly.
Old Feb 20, 2014 | 08:12 PM
Biggyrat's Avatar
4th Gear
Try again! /tsb/3gTL/b05-020.pdf
Old Feb 20, 2014 | 08:15 PM
Biggyrat's Avatar
4th Gear
If this didn't come across with the http: I can't help.
Old Feb 20, 2014 | 09:49 PM
Will Y.'s Avatar
Don't worry about it-- all the TSBs are available at: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-technical-service-bulletins-tsbs-3g-garage-j-016-a-613659/ .
Follow the instructions in red at the top of the thread to get access to the .pdf sheets.
There are videos on removal of the HFL on YouTube as well as in several threads here on AZ.
Welcome to AZ.
handsom-hustla
Nov 13, 2015 05:04 PM
ibGTV
Sep 28, 2015 03:40 AM
gemz_acura
4G TL Problems & Fixes
15
Sep 26, 2015 06:12 PM
Phambam12
Sep 6, 2015 06:57 PM
chrisr
5G TLX Problems & Fixes
Aug 31, 2015 08:24 PM
