Clicking Sound, Axle Issue?
i recently noticed a clicking or clunking sound when i cut the wheel all the way to the end to turn the car(from a stop and roll). im guessing something is wrong wit hthe axle. Since my warranty is expured, should i bring i tto a local shop and let them check it out? how much would a new axle cost for the TL?
what kind of effects does a messed up axle have on the driving/suspension, if any?
Clicking Noises from start/stop 10mph roll
I too have this clicking problem when I start. stop or break, or turn at low speeds. Weird right? I thought it was the break system but then maybe the shocks. But an CVS boot is definitely possible. I'm calling ChevyChase Acura now to see if that's a possible fix.
I'll update as needed.
WHEN the protective boot gets torn- and one or more of them will at some point in life- all the grease for the BEARING inside goes out, and all the outdoor world road grit goes in and causes the bearing to sieze- that bad!
Requires replacement of CV-Axle shaft assembly
no you cant replace the boot- the damage is already done inside
Have a local shop do it- simple job with the right tools
Call NAPA auto parts- they have new ones for gen2, hopefully you guys too
Other places will have rebuilts-Its just nice to get new for same price when available
REDBULL///AMG
I sent it to ChevyChase to fix and the issue came out to be the binding on the left front control arm. Replaced bolts on it and now it's fine.
Good luck everyone.
Good luck everyone.
05 TL
Is there a TSB for this? I hate my dealer, they will do the cheapest thing possible to fix it (new boot, new grease... ) Its clicking... Thus there is something out of tolerance; but they are going to patch the problem, not fix it.
Thanks.
Thanks.
yeah i wanna add that my car had this clicking sounds when i shift gears n g slow like when i drive slow you'll hear clicking sound till u hit at least over 15mph and it stops any suggestions??
-=2005 TL=-
1 Post
I think I have the same problem as everyone else here, a bad axle....can anyone please post a DIY when they replace their axle? Preferrably the driver's side axle. Oh, if anyone has a DIY on replace front wheel bearings as well. Thank you.
-=2005 TL=-
1 Post
Originally Posted by Kracker
Topckret... Buy a service manual. You will never regret it.
The stupid manuals at autozone dont count.. Get the factory service manual.
05 TL
Dont quote me on this... But I think the part number you want is
Part #: 61SEP02
http://www.helminc.com/helm/welcome_...M9H21XRDJ90VQ3
It looks like its 75 bux
https://acurazine.com/forums/showthread.php?t=144764
As far as searching I have had alot more luck with google's site:tl.acurazine.com ####
Part #: 61SEP02
-=2005 TL=-
1 Post
Part #: 61SEP02
Part #: 61SEP02
justin7779
12-25-2015 10:33 PM
