check engine light w/ VSA light problem.
Old Sep 7, 2010 | 06:10 PM
juriza07_T-La's Avatar
this keeps occuring. my 05 TL keeps having the same problem. during driving the VSA and Check Engine light will turn on, and the car will go into limp mode while i am driving. went to a local shop. and nothing can be found. i need some advice before spending money at a dealer just to take a look at it. thankyou
Old Sep 7, 2010 | 08:14 PM
Opel's Avatar
does this happen under aggressive/high rev driving or normal driving.......if it happens while you drive aggressively, it can be that you're low on oil...if it happens while driving normal, it can be the TPS-Throttle Position Sensor.
the shop you went to, couldn't pull any DTC codes?..... from what you're saying, once the CEL is triggered, it should store a code, so the shop should have been able to read a code with a simple OBDII scanner.
Old Sep 7, 2010 | 09:10 PM
yes i just found out that is it the TPS. the thing is i cant find that part number anywhere so i can have it replaced. sorry in new to this. ive only had my TL for about two months. hopefully this fix isnt too costly
Old Sep 7, 2010 | 09:15 PM
Opel's Avatar
Part #2 You can do this yourself
http://acuraautomotiveparts.org/acur...s=&view=normal
Old Sep 7, 2010 | 09:46 PM
thankyou for your help. i'll be ordering teh part very soon. hope its not to hard to replace. im sure there has to be a DIY somewhere or instructions atleast.
Old Sep 8, 2010 | 06:02 PM
rex1's Avatar
Im having this exact same problem, thanks opel!!
mada51589
Jan 9, 2025 04:40 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
