Check Engine Light SOS !! A/F Sensor?
Old Jul 23, 2013 | 12:16 PM
mAgn8's Avatar
Hi Aziners, I really need some help my cars check engine lights keeps reappearing even after pulling the negative battery to reset ecu... Took to autozone for quick diagnostic and results read A/F sensor malfunction code
P0134.
Been driving for a week with problem and car just does not drive the same, performance and fuel economy dropped very low, acceleration and engine studdering as well.
Any suggestions and advice would be helpful and appreciated, thanks guys!!
Oh I drive an 07 TL Type -S btw
Old Jul 23, 2013 | 02:20 PM
I hate cars's Avatar
I believe that's the rear upstream sensor. Just replace the 02 sensor.
Old Jul 23, 2013 | 03:56 PM
mAgn8's Avatar
Thanks, ill look into that, from the diagnostic results its calling it Sensor 1 but doesn't say upstream or downstream bank 1 or bank 2
Old Jul 23, 2013 | 05:31 PM
It says bank 1 sensor one or bank 1 front sensor. That would make it the primary 02 sensor on the firewall side. If you're unsure that the 02 is your problem you can switch the primary 02s and see if it pops a code for the other bank.
Old Jul 23, 2013 | 09:27 PM
vietxquangstah's Avatar
sensor 1 = upstream
sensor 2 = downstream
that's pretty much universal for all makes and models.
Old Jul 26, 2013 | 09:02 AM
mAgn8's Avatar
Ordered an oem o2 sensor for the rear upstream bank, it seems theyre calling it an A/F sensor now days... Will install when it arrives and hope that fixes the problem, thanks for info guys.
Old Jul 26, 2013 | 11:51 AM
A/F sensor is just a term most dealerships use. You would be surprised at how dealerships call their parts completely different names than what everyone outside the dealership knows them as.
Old Jul 27, 2013 | 03:40 PM
mAgn8's Avatar
Just installed oem sensor and car running great like before again, and check engine light hasn't reappeared, thanks again fellas !!
Old Aug 19, 2013 | 08:45 PM
paulmnly's Avatar
Sorry to bring this thread back to life but I'm having a similar problem. 2005 Acura TL. Pulling P0134 P0135 and P2195. Gas mileage is TERRIBLE and throttle response is terrible. I understand I may have to replace the O2 sensors but do I need to replace more than 1 as I have all of these codes? I don't believe the muffler has a leak as its not making any crazy noises. HELP! Auto zone is telling me it's $200 for the Air/Fuel O2 sensor but I want to make sure I'm not pouring $ in the wrong direction first. Thank you!
Old Aug 19, 2013 | 08:55 PM
paulmnly's Avatar
Also... My a/c will blow cold for a while and then starts blowing out regular air from outside. It's like it's out of freon but when I check, it doesn't have any leaks and the lines are still compressed at 60psi. Would there be any correlation with the a/c not working and the O2 sensor being bum?
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
