Check engine light flashes on launch?!?!
Old Dec 22, 2009 | 02:44 PM
n3o's Avatar
n3o
My CEL flashes whenever I aggresively launch the car. Anyone have this happen to them or know what the cause could be? Car is an '04 6mt tl.
Old Dec 22, 2009 | 03:35 PM
NCTL05's Avatar
Middle Finger anyone?
You sure it is the check engine light and not the traction control warning light? The traction control light is a triangle with an exclamation mark in the middle. Whenever you launch hard with the traction control on and still manage to spin a little the light will flash.
Old Dec 22, 2009 | 03:45 PM
barnash22's Avatar
I have an 06 TL and never had this problem. I always turn the VSA off, just makes the car more fun to drive. But with that comes the annoying triangle that wont go away.....
Old Dec 28, 2009 | 09:31 AM
n3o's Avatar
n3o
It was most definately not the VSA light. Its the little engine block under the speedo. If I do any kind of aggresive launch where it wheel hops it seems the CEL will flash for like 8 seconds.
Old Dec 28, 2009 | 10:19 AM
Bender's Avatar
can you get the cell code?
Old Dec 28, 2009 | 12:39 PM
n3o's Avatar
n3o
No because it doesn't stay on. It flashes for 8 seconds and then goes away.
Old May 17, 2011 | 08:28 PM
ANTHONY741's Avatar
I have had the same problem on my 04 TL since I bought it and dealer never gets a code. It has happened about 5 times now and all were upon heavy acceleration. It flashes for 8-10 secs and goes away. I don't notice any performance issues
Old May 18, 2011 | 12:15 AM
SpiderX1016's Avatar
I'd see if there are any Pending/Stored codes. Blinking CEL and you may end up with a damaged CAT.
How many miles do you have? Have you changed the spark plugs?
Old May 18, 2011 | 08:26 AM
nfnsquared's Avatar
Most of these cases (MIL while under heavy acceleration) are fixed by a reflash of the PCM. What year is your TL?
Old May 18, 2011 | 03:50 PM
~Lefty~'s Avatar
^That, but normally a flashing CEL is a severe misfire. But if you're not noticing any performance issues while accelerating, then I would check into what nfnsquared said...
Old May 18, 2011 | 04:50 PM
nfnsquared's Avatar
In the cases I'm referring to, the PCM is falsely sensing a misfire due to a software/firmware glitch and the reflash corrects this.
There are 2 or 3 TSBs that cover this, depending on year/model.
Old Dec 26, 2015 | 03:29 AM
paperboy42190's Avatar
Any tsb's for 07 type S? I did a quick WOT run earlier on the freeway onramp like 40-80 ish, and the check engine light flashed for about 10 seconds and stopped. However the car ran perfectly fine.
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
