Check engine light flashes
Old Oct 11, 2012 | 10:10 PM
godfather18's Avatar
I have a 2004 TL with 161k miles and today noticed that the check engine light would flash for a few seconds but only with the key turned but the car not started. It only flashes with the car not turned over only with the key turned to the on position and then it goes away. Car drives perfectly fine no issues and check engine light doesnt come on or flash while im driving.
Old Oct 11, 2012 | 10:59 PM
Anyone?
Old Oct 11, 2012 | 11:41 PM
LaCostaRacer's Avatar
I think that is normal. This is so a technician can determine if the bulb is good. Some people have been known to defeat the check-engine light so seeing the light briefly turn on at startup is a good indication that the bulb functions.
Old Oct 11, 2012 | 11:58 PM
MEKO's Avatar
May be the check engine light needs to be checked
Old Oct 12, 2012 | 12:13 AM
BukvaMan's Avatar
Its normal, mine does it every time from day one ... not that i can remember but yeah still very sure that its a normal behavior....
Old Oct 12, 2012 | 06:29 AM
Ok thanks for the input guys now I can sleep better at night now LOL
Old Oct 12, 2012 | 07:09 AM
nfnsquared's Avatar
You guys ever read your owner's manual? p.243 (2004 manual)
A flashing MIL with the key in the ON position (engine off) is not normal and means the readiness codes are not set.
http://techinfo.honda.com/rjanisis/p...404O00242B.pdf
Old Oct 12, 2012 | 08:37 AM
RaviNJCLs's Avatar
MikeYutkin
Sep 10, 2015 10:13 PM
Bahamanurse1
Sep 10, 2015 10:05 PM
HeloDown
Sep 8, 2015 06:51 PM
bryan zaragoza
Sep 8, 2015 12:28 AM
whitesoxsfan12
Sep 7, 2015 04:07 PM
