CEL: P0141 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
Old Jul 24, 2009 | 12:23 PM
CometVR4's Avatar
I get this Check engine light a couple days ago and the code reads: -P0141 Oxygen Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
I replaced the O2 sensor on the front bank downstream after the catalyic converter. I unplugged positive on the battery for a few seconds and the CEL came back on after just a few seconds after start up. Need help, any advice?
Old Jul 24, 2009 | 02:22 PM
RACINGHART03's Avatar
Bank one is the rear of the engine by the firewall. Is that the one you changed?
Old Jul 24, 2009 | 06:37 PM
CometVR4's Avatar
No, I changed the one closer to the front bumper. If bank one is rear of engine that would explain why the light keeps coming on. I had someone clear it with a OBDII scanner and it popped on within 15 seconds after restart of the engine.
Old Jul 26, 2009 | 11:23 PM
240sx acura tech's Avatar
acura master tech
bank one is in the rear. im not sure if they are the same. one is longer then the other.
Old Jul 29, 2009 | 08:21 PM
That explains it!
Old Aug 4, 2009 | 02:10 PM
CometVR4's Avatar
Just want to give an update. I swapped the 02 out for the rear downstream. The CEL has been off for almost a week now. Thank you everyone for your help.
Old Aug 4, 2009 | 03:08 PM
DanL's Avatar
If it's any consolation, when the heater circuit on one fails, the other often isn't all that far behind.
Old Aug 4, 2009 | 04:38 PM
CometVR4's Avatar
Good to know, The front one (bank 2) is found is easier to change.
Mike Pilipenko
Mar 26, 2024 09:21 PM
Jamus22
Jun 11, 2023 10:08 AM
RobbDizzle
Oct 15, 2015 11:16 AM
07Acuradude
Sep 29, 2015 03:01 PM
thegipper
Sep 28, 2015 01:01 PM
