Car won't start after 2 hours
Old Nov 13, 2014 | 05:49 PM
g465777's Avatar
7th Gear
my tl has been having an issue for the past 2 years where if i dont start my car for just one day it wouldnt start. well since its winter now its cut down to about 2 hours. i just got back from autozone with them telling me the battery and alternator is fine. is there any idea on whats going on?
Old Nov 13, 2014 | 05:51 PM
g465777's Avatar
7th Gear
just noticed the problems section sorry for mislocating this
Old Nov 13, 2014 | 06:05 PM
guitarplayer16's Avatar
It is quite all right sir.
Unplug the HFL, that should fix your problem.
https://acurazine.com/forums/problem...elated-892004/
Old Nov 13, 2014 | 07:02 PM
g465777's Avatar
7th Gear
thanks just did it, now have to wait a couple of hours for a result
Old Nov 13, 2014 | 07:06 PM
truonghthe's Avatar
Keep us updated.
Old Nov 13, 2014 | 07:41 PM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
How old is your battery? Lots of Acurazine members have reported batteries testing okay only to find out after replacing it, that was the source of their problem. Internal cell failure is difficult to test for.
I hope disconnecting the HFL solves your issue but note if your battery has been dead multiple times (aka deep cycling) you may need a new one anyway.
Keep us posted.
Old Nov 13, 2014 | 08:28 PM
TacoBello's Avatar
Yes sirs, I was thinking the same two things- either HFL or the battery has past it's prime. How old is your current battery? Still the original? What year is your car?
Not sure if you care, but the HFL is easy to replace, but somewhat expensive. If that is causing your drain, you can either leave it unplugged, or pick up another one online for about $200.
Old Nov 13, 2014 | 11:10 PM
g465777's Avatar
7th Gear
the car is a 2008, and the battery is just about 2 years old. thing is even after a week of buying my new battery and couldnt start it without a jump. got the battery replaced (duralast gold- dont know their reputation but i thought it was a good choice at the time) and it just drained in the same amount of time.
long story short i took out the HFL, which is never used since it took all its time trying to boot up whenever i did want to try it out. i noticed that the little black box it was held in was fairly warmer than everything else that was inside the car so it was pulling some power. just started the car again and its been going on 3 hours so i think that was the main issue. just to be safe though ill post whether or not it starts tomorrow since its fairly cold over here, overnight rest should be enough to kill the battery if the problem wasnt fixed.
thanks guys
Old Nov 13, 2014 | 11:17 PM
g465777's Avatar
7th Gear
sorry for my english. i was born and raised in texas, but i cant put together a sentence right now lol. i really dont plan on replacing the HFL right now; im just happy that one of the potential problems is out of the car. i havent been able to use my car at all this week until today since it was my day off.
Old Nov 13, 2014 | 11:18 PM
NBP04TL4ME's Avatar
If you had the constant trying to boot up and the upper center console was warm, then you definitely have a bad HFL. You should be better off now that it is disconnected. Only question is how much damage has it done to your battery.
Old Nov 13, 2014 | 11:23 PM
g465777's Avatar
7th Gear
hoping not too much but it has been a while sooo . the guy at autozone said i have 78% on the battery still. im not too car mechanically savy and dont have the stuff to check out the battery myself.
Old Nov 14, 2014 | 05:34 AM
NBP04TL4ME's Avatar
If you live in a cold weather area, the frigid temps will do the battery test for you.
Old Nov 14, 2014 | 02:08 PM
g465777's Avatar
7th Gear
well i do see that youre in mass, our weather doesnt compare to yours over there. the arctic mass is just doing its thing over here in texas right now too.
car started fine today with no choking . of all the problems it could have been im a little surprised it was due to the HFL, i was expecting it would have costed over $200 to get this fixed.
Old Nov 14, 2014 | 02:18 PM
NBP04TL4ME's Avatar
It's definitely cooler than it is supposed to be but we aren't having the crazy cold temps they have experienced in the uppper mid-west.
The HFL issue is unfortunately fairly common. So far I haven't had the issue in 11 years of 3G TL ownership, but did have to replace it on our MDX. If you search here on AZ, you will find quite a few threads on this. There are multiple remedies from simply disconnecting and doing without (which I wouldn't do) to baking the PC board, replacing of diodes, soldering and replacement.
TL-Rocket
Apr 29, 2023 02:33 AM
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
