Car Won't Start
Old Jun 2, 2010 | 04:29 PM
art1188's Avatar
Car Won't Start
Hey guys,
I just came back from a road trip a couple days ago, parked my car in the garage, and now when I go to start it I can't do it. I put the key in, turn it two clicks (for accessory power) and the dash lights up but it kind of flickers and dims randomly. I tried to start the car but it doesn't turn over (maybe tries for 1/2 a second then nothing). Tried to jump start it with my bro's car but I couldn't start it either. I wish I could say its the fault of a dead battery but If I couldn't jump start it there must be something else right? I'm thinking either key needs to be reprogrammed (this is what the dealer suggested when I called) or maybe the alternator? Anyone had this problem before or know how to fix it?
Old Jun 2, 2010 | 04:52 PM
shadowkahn's Avatar
Try to jump it again.
Or put a known good battery in there.
It's not your alternator.
Old Jun 2, 2010 | 05:10 PM
Turbonut's Avatar
Probably the battery, but make certain the cables are tight and clean. If there is a cable connection problem, the jumpers won't work either. Turn on the interior lights and give it a try, if they go dim or out when trying to start, electrical supply problem, bat or cables. If no go, remove the bat and have it tested.
Old Jun 2, 2010 | 09:12 PM
guitarplayer16's Avatar
Generally, when your lights go dim, it is an indicator that there is not enough juice in the battery to start the car.
I remember when I couldn't start my car a month ago.
Replaced the starter, everything's good =)
Old Jun 3, 2010 | 06:20 AM
myblack04tl's Avatar
Turbonut is right, the first place I would check is the connections on the battery. My Mom's battery was fine but there was alot of corrosion on the positve terminal. I cleaned it off and she has had no problems.
Old Jun 3, 2010 | 09:41 PM
SpeedFactor's Avatar
5th Gear
If the battery is really dead, it acts like a resistor and makes it hard to jump.
Feb 25, 2020 09:57 AM
bearingman07936
Jan 7, 2016 03:22 PM
jordanboi
Sep 5, 2015 01:33 AM
Stu2414
4G TL Problems & Fixes
Aug 30, 2015 07:30 PM
