Car suddenly won't start
My gas tank was on empty. I made it to the gas station just in time. Rode home, went in the house for five minutes, came back out to start car and the car suddenly would not start. The battery is one month old, the lights, radio etc are working. When I turn the key I hear a faint humming sound for a few seconds then nothing. Any ideas?
Does the car turnover but not start?
Yes, it does turnover but not start. I noticed that the key is flashing on the dashboard as soon as I insert the key into the ignition. Is it possible that there is a problem with the key. I may have put it against something magnetic (if this can cause the key to stop working).
LowNslowTL
1.)fuel issue, which sounds more likely than the other two
2.)spark issue
3.)air issue
If you know for a fact your starter is engaging and the motor is turning over but not starting, then you are not getting the proper fuel/air/spark mixture to start the motor. Like stated before, if you run the tank down to low you run the chance of ruining the fuel filter and/or damaging the fuel pump. Id check fuel pressure and report back.
maybe your fuel pump? i did that on my passat would drive around with low gas till one day it shut off on me while driving it would crank and all the light would be on be it would turn to drive so it turned out to be the fuel pump
To clear if it's the fuel or not
Tell us how low was the tank. Where was the needle exactly? Or how many gal the tank took.
Do you do this often
andysinnh
09-05-2015 11:38 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
