Car slow as sh*t when warm
Old Oct 28, 2012 | 06:50 PM
Nick216's Avatar
The Boss
title is self explanatory, seems that i can only do a burnout or make the tires screech when the cars cold, but after its warm it will not do any sort of screeching. told the dealer many times that i thought my car was running bad when warm they insisted everything was fine. any ideas
~ and also as im in a hurricane right now lmao, u think my plastidip will hold up?
*edit* with VSA off
Old Oct 28, 2012 | 07:03 PM
SpiderX1016's Avatar
Tires grip better when they're warm.
Burnout with a 5at? Lol
Old Oct 28, 2012 | 07:11 PM
Nick216's Avatar
The Boss
lmao yes a burnout with an auto . and i guess the sticky tires when warm makes sense, but wuta bout the slow acceleration. ive been told many things like warmer air= less oxygen, a bad sensor
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
In colder weather most vehicle will perform better due to the lack of condition called "Heat soak"
Plasti-dip wheels, grill, ect ect is tacky imo, just redo it and regardless winter is rolling up it's not a forever thing.
Try upgrading installing a CAI and a TB coolant bypass to help with heat soaking issues and take it a step higher Thermo gaskets and ported intake runners.
At the end of the day TL is still slow, unless your doing serious work.
Stay classy New York.
Old Oct 28, 2012 | 07:17 PM
Nick216's Avatar
The Boss
yea ppl have told me the plastidip looks cheap but hey ide rather that then a oxidized and stained grill. and yea ill look into a CAI soon, my tl's powertrain is stock i guess thats the first step.
Old Oct 28, 2012 | 07:21 PM
ez12a's Avatar
the overexplainer
I've gone and sprayed my plasti dipped grille point blank with a pressure washer at those coin op car washes with no problems.
Unless you get massive amounts of debris flying in the air you'll be fine.
Old Oct 28, 2012 | 07:25 PM
Nick216's Avatar
The Boss
lmfao if theres debris flying i got bigger problems then my plastidip
Old Oct 28, 2012 | 07:27 PM
JORTS's Avatar
Since when do you judge your car being fast or slow based on being able to do a burnout? Crazy I say
Old Oct 28, 2012 | 08:58 PM
JBONN's Avatar
Vegas Bum
There is another thread here that points to the battery being the source of the power loss during temps above 25c.
Old Oct 28, 2012 | 10:03 PM
Nick216's Avatar
The Boss
hmm u kno if it talked bout low voltage or just crappy oem battery?
Old Oct 28, 2012 | 10:34 PM
350's Avatar
350
My first ricer
IAT and intake get heat soaked, which leads it to cut timing. A CAI doesn't add much power but will keep it from losing as much once warmed up. Also PlastiDip FTW screw the haters lol. I'm gonna do my whole car in the spring.
Old Oct 28, 2012 | 11:06 PM
1black_seven's Avatar
Slot Machine Lubricator
I wouldn't go overboard with the plastidip, but when applied just right it adds to the over all style.
Old Oct 28, 2012 | 11:15 PM
03tLsNBP's Avatar
MechEng
You could make your own vented heat extractor hood like me
Not done yet but I will post up a DIY when it's finished. Still need to finish the extractor part. Right now it's just a vent.
Old Oct 29, 2012 | 07:01 AM
Shoot2Thrill's Avatar
Walk the walk
I'm thinking the whole heat soak thing is not the battery but the notorious leaky EVAP Canister Purge Valve.
Old Oct 29, 2012 | 07:09 AM
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
*edit* with VSA off
The tires will screech or chirp more when it's cold because the tires are cold and they have less "grippyness." So yes, your car is fine.
Old Oct 29, 2012 | 10:46 AM
Guiltyox's Avatar
Reset your ecu. I couldn't tell you how to do it, since my TL-S is 6MT, but there are threads on here about it.
Old Nov 1, 2012 | 01:46 PM
JBONN's Avatar
Vegas Bum
You are in luck...I was feeling helpful today, check out this thread:
https://acurazine.com/forums/showthr...hlight=battery
Feb 25, 2020 09:57 AM
1lowtc
1G RDX (2007-2012)
15
Nov 19, 2015 10:52 AM
kuzdu
Sep 10, 2015 08:42 PM
NSolace
Sep 3, 2015 08:14 PM
