Car slow as sh*t when warm
title is self explanatory, seems that i can only do a burnout or make the tires screech when the cars cold, but after its warm it will not do any sort of screeching. told the dealer many times that i thought my car was running bad when warm they insisted everything was fine. any ideas
~ and also as im in a hurricane right now lmao, u think my plastidip will hold up?
*edit* with VSA off
*edit* with VSA off
lmao yes a burnout with an auto
. and i guess the sticky tires when warm makes sense, but wuta bout the slow acceleration. ive been told many things like warmer air= less oxygen, a bad sensor
In colder weather most vehicle will perform better due to the lack of condition called "Heat soak"
Plasti-dip wheels, grill, ect ect is tacky imo, just redo it and regardless winter is rolling up it's not a forever thing.
Try upgrading installing a CAI and a TB coolant bypass to help with heat soaking issues and take it a step higher Thermo gaskets and ported intake runners.
At the end of the day TL is still slow, unless your doing serious work.
Stay classy New York.
I've gone and sprayed my plasti dipped grille point blank with a pressure washer at those coin op car washes with no problems.
Unless you get massive amounts of debris flying in the air you'll be fine.
IAT and intake get heat soaked, which leads it to cut timing. A CAI doesn't add much power but will keep it from losing as much once warmed up. Also PlastiDip FTW screw the haters lol. I'm gonna do my whole car in the spring.
You could make your own vented heat extractor hood like me
Not done yet but I will post up a DIY when it's finished. Still need to finish the extractor part. Right now it's just a vent.
*edit* with VSA off
*edit* with VSA off
You are in luck...I was feeling helpful today, check out this thread:
https://acurazine.com/forums/showthr...hlight=battery
Mugen TSX
Eastern Canada
Sep 1, 2015 11:05 PM
