Car Not Starting Error P16BF
That's a new one on me. Google (your friend) says it's a starter cutout relay circuit issue. Are you 6MT or AT?
Do you have an aftermarket alarm installed?
There is aftermarket remote starter installed by previous owner. There were no issues what so ever. I have left car for 2 hourse, came back and could not start the car. Everything seems to run perfectly its just not turning the engine and says "check ignition system" To note its been drizling rain for past couple of hours.
Can you start the car via the remote start?
Try giggling the shift lever while in Park.
Could be a fault RS install, bad starter cut out relay, bad transmission range switch.
Hello, I was able to start the car this morning from the first try as any other day. With not problem
What I found that, with remote starter car can start but only runs for 5 secs and shuts down and tries to restart again, runs for 5 secs and shuts down. for about three times.
I know for sure that I have started the car with remote starter last week. By the time i got to the car, car was still running about 5min.
Guys were installing formulaone tints for me yesterday Guys told me that car started by it self, when they were installing tints. Which is hard to believe.
saberlove
03-11-2021 09:29 AM
bearingman07936
01-07-2016 03:22 PM
