Car is Devouring Coolant
So I had a coolant leak and ended up getting a new reservoir tank for my TL-S. When I removed the old tank and emptied the coolant i found it was missing a rubber stopper and that was probably causing the leak. The leak was visible as I could see coolant sprayed on and around the reservoir tank.
Now with the new tank I don't see any visible coolant leak, but each time I check the tank is back below the minimum fill line. Not sure what's going on here, I probably drive about 4 miles a day to and from work. Any ideas?
Latent car nut
Do you refill it between drives?
It could just the radiator is sucking in coolant very normal.
The following 2 users liked this post by thoiboi:
Acura TL Builder (06-25-2019),
EvilVirus (06-26-2019)
Yeah I've been refilling between drives after the engine cools down but I'm running out of coolant..
That's what I'm hoping. Not too familiar with this stuff. I appreciate the responses though. I'll keep refilling and keep an eye on it.
if you keep having to top off the radiator itself, then you have a leak somewhere else. Then it's time to remove the lower splash shield and take a look, also by the coolant lines by the throttle body + the heater hoses + heat exchanger piece on top of the transmission.
I read it as he was checking the rad overflow tank, and not the radiator itself.
Latent car nut
Acura TL Builder (06-26-2019)
pressure test cooling system, be sure to put heat on max and burp air from system when filling up with coolant
Any coolant puddling on the pavement? Check your heater control valve (on the firewall, do a search for a DIY by Majofo). My HCV literally melted and that's where I was losing coolant. Another possibility is your water pump weeping fluid....
KongZTT MD (2.2 CL)
1G CL Problems & Fixes
02-07-2011 08:35 PM
xasnxkiddox
11-21-2006 11:56 AM
BLaCk Acc
11-01-2004 02:12 PM
